--- title: "system.file.readFileAsBytes" description: "Opens the file found at path filename, and reads the entire file." --- # system.file.readFileAsBytes > Opens the file found at path filename, and reads the entire file. This function is used in **Python Scripting**. ## Description Opens the file found at path filename, and reads the entire file. Returns the file as an array of bytes. Commonly this array of bytes is uploaded to a database table with a column of type BLOB (Binary Large OBject). This upload would be done through an INSERT or UPDATE SQL statement run through the system.db.runPrepUpdate function. You could also write the bytes to another file using the system.file.writeFile function, or send the bytes as an email attachment using system.net.sendEmail. :::note This function is scoped for Perspective Sessions, but since all scripts in Perspective run on the Gateway, the file must be located on the Gateway's file system. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.file.readFileAsBytes(filepath)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `filepath` | The path of the file to read. ### Returns **List[Byte]** - The contents of the file as an array of bytes. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This code would prompt the user to choose a file. If the user chooses a file, it would then read that file and upload it to a database table called Files into a BLOB column called file_data. path = system.file.openFile() if path != None: bytes = system.file.readFileAsBytes(path) system.db.runPrepUpdate("INSERT INTO Files (file_data) VALUES (?)", [bytes]) ```
