system.file.readFileAsBytes
Descriptionβ
Opens the file found at path filename, and reads the entire file. Returns the file as an array of bytes. Commonly this array of bytes is uploaded to a database table with a column of type BLOB (Binary Large OBject). This upload would be done through an INSERT or UPDATE SQL statement run through the system.db.runPrepUpdate function. You could also write the bytes to another file using the system.file.writeFile function, or send the bytes as an email attachment using system.net.sendEmail.
This function is scoped for Perspective Sessions, but since all scripts in Perspective run on the Gateway, the file must be located on the Gateway's file system.
Syntaxβ
system.file.readFileAsBytes(filepath)
Parametersβ
| String | filepath | The path of the file to read. |
Returnsβ
List[Byte] - The contents of the file as an array of bytes.
Scopeβ
Code Examplesβ
# This code would prompt the user to choose a file. If the user chooses a file, it would then read that file and upload it to a database table called Files into a BLOB column called file_data.
path = system.file.openFile()
if path != None:
bytes = system.file.readFileAsBytes(path)
system.db.runPrepUpdate("INSERT INTO Files (file_data) VALUES (?)", [bytes])
