--- title: "system.eventstream.publishEvent" description: "Publishes a message to a Gateway Event Source." --- # system.eventstream.publishEvent > Publishes a message to a Gateway Event Source. This function is used in **Python Scripting**. ## Description Publishes a message to a Gateway Event Source. You can publish a message to the local Gateway, or a remote Gateway. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.eventstream.publishEvent(project, path, message, acknowledge, [gatewayName])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `project` | The project the event stream(s) belong to. | | String | `path` | The path to the event stream resource. | | String | `message` | The string message to send. | | Boolean | `acknowledge` | If True, further messages will be blocked until the receiving Gateway Event Listener source finishes processing the current message. If False, further messages will not be blocked while waiting for a response from the Gateway Event Listener source. | | String | `gatewayName` | The Gateway Name of the remote Gateway you want to send the message to. Not specifying a remote Gateway or using `None` will send the message to the specified event stream path and project on the local Gateway. [Optional] | ### Returns **PyDictionary** - A dictionary of key and value status pairs resulting from publishing the specified event stream. Keys returned include: * errorMessage * stage * status ### Scope Gateway ## Code Examples ```python title="Example #1" # Sends the specified message to the "listener" event stream located within the "event-stream" project. system.eventstream.publishEvent("event-stream", "listener", "I am a message!", True) ``` ```python title="Example #2" # Parses the message payload as a JSON object using the jsonEncode function, after which publishEvent will then send the message to the project called "myProject". project = "myProject" path = "myEventStream" rawMessage = {'value': self.getSibling("TextField").props.text} acknowledge = True gatewayId = None message = system.util.jsonEncode(rawMessage) system.eventstream.publishEvent(project, path, message, acknowledge, gatewayName) ```
