Version: 8.3
system.eventstream.publishEvent
Publishes a message to a Gateway Event Source. You can publish a message to the local Gateway, or a remote Gateway.
system.eventstream.publishEvent(project, path, message, acknowledge, [gatewayName])
StringprojectThe project the event stream(s) belong to.
StringpathThe path to the event stream resource.
StringmessageThe string message to send.
BooleanacknowledgeIf True, further messages will be blocked until the receiving Gateway Event Listener source finishes processing the current message. If False, further messages will not be blocked while waiting for a response from the Gateway Event Listener source.
StringgatewayNameThe Gateway Name of the remote Gateway you want to send the message to. Not specifying a remote Gateway or using None will send the message to the specified event stream path and project on the local Gateway. [Optional]
PyDictionary - A dictionary of key and value status pairs resulting from publishing the specified event stream. Keys returned include:
  • errorMessage
  • stage
  • status
Gateway
Example #1
# Sends the specified message to the "listener" event stream located within the "event-stream" project.
system.eventstream.publishEvent("event-stream", "listener", "I am a message!", True)
Example #2
# Parses the message payload as a JSON object using the jsonEncode function, after which publishEvent will then send the message to the project called "myProject".
project = "myProject"
path = "myEventStream"
rawMessage = {'value': self.getSibling("TextField").props.text}
acknowledge = True
gatewayId = None
message = system.util.jsonEncode(rawMessage)
system.eventstream.publishEvent(project, path, message, acknowledge, gatewayName)
