--- title: "system.eam.queryAgentHistory" description: "Returns a list of the most recent agent events." --- # system.eam.queryAgentHistory > Returns a list of the most recent agent events. This function is used in **Python Scripting**. ## Description Returns a list of the most recent agent events. This function can only be called from the Controller. If called from an Agent, this function will return an exception. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.eam.queryAgentHistory(groupIds, agentIds, startDate, endDate, limit)` ### Parameters Type | Parameter | Description ------- | ------- | ----- List| `groupIds` | A list of groups to restrict the results to. If not specified, all groups will be included. List| `agentIds` | A list of agent names to restrict the results to. If not specified, all agents will be allowed. Date| `startDate` | The starting time for history events. If null, defaults to 8 hours previous to now. Date| `endDate` | The ending time for the query range. If null, defaults to "now". int| `limit` | The limit of results to return. Defaults to 100. A value of 0 means "no limit". ### Returns **Dataset** - A dataset with columns id, agent_name, agent_role, event_time, event_category, event_type, event_source, event_level, event_level_int, and message, where each row is a new agent event. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 -Querying for Agent Task History" # This script will loop through each row of the dataset and grab out every value from that row and assign it to a matching variable. Those variables can then be used in some way. results=system.eam.queryAgentHistory() for row in range(results.rowCount): eventId=results.getValueAt(row, "id") agentName=results.getValueAt(row, "agent_name") agentRole=results.getValueAt(row, "agent_role") eventTime=results.getValueAt(row, "event_time") eventCategory=results.getValueAt(row, "event_category") eventType=results.getValueAt(row, "event_type") eventSource=results.getValueAt(row, "event_source") eventLevel=results.getValueAt(row, "event_level") eventLevelInt=results.getValueAt(row, "event_level_int") message=results.getValueAt(row, "message") #Can include some code here to use the variables in some way for each row. ``` ```python title="Example #2 - Querying for Agent Task History" # This script grabs the agent event history from agents called Agent1, Agent2, Agent3, and will then place the data into a table on the same window. results=system.eam.queryAgentHistory(agentIds=["Agent1", "Agent2", "Agent3"]) event.source.parent.getComponent('Table').data = results ```
