system.dnp3.selectOperateBinary
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Descriptionβ
Issues a Select-And-Operate command for digital control operations at binary output points (CROB).
Permission Type: DNP3 Management
Syntaxβ
system.dnp3.selectOperateBinary(deviceName, indexes, opType, tcCode, [count], [onTime], [offTime])
Parametersβ
| String | deviceName | The name of the DNP3 driver. |
| List | indexes | A list of indexes of the objects to be modified in the outstation. |
| Integer | opType | The type of operation. 0=NUL, 1=PULSE_ON, 2=PULSE_OFF, 3=LATCH_ON, 4=LATCH_OFF |
| Integer | tcCode | The Trip-Close code, used in conjunction with the opType. 0=NUL, 1=CLOSE, 2=TRIP |
| Integer | count | The number of times the outstation shall execute the operation. [optional] |
| Integer | onTime | The duration that the output drive remains active, in millis. [optional] |
| Integer | offTime | The duration that the output drive remains non-active, in millis. [optional] |
Returnsβ
The DNP3 status code of the response, as an integer.
Scopeβ
Code Examplesβ
Example #1
# This example shows latching on 3 binary output points with the Select-And-Operate command.
latch = system.dnp3.LATCH_ON
system.dnp3.selectOperateBinary("Dnp3", [0, 1, 2], latch)
Example #2
# This example shows setting a binary output point at index 3 to pulse at 5 second intervals
# with the Select-And-Operate command.
pulse = system.dnp3.PULSE_ON
trip = system.dnp3.TRIP
system.dnp3.selectOperateBinary("Dnp3", [3], pulse, trip, 2, 5000, 5000)
