Version: 8.3
system.dnp3.selectOperateAnalog
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Issues a Select-And-Operate command to set an analog value in an analog output point.
Permission Type: DNP3 Management
system.dnp3.selectOperateAnalog(deviceName, index, value, [variation])
StringdeviceNameThe name of the DNP3 device driver.
IntegerindexThe index of the object to be modified in the outstation.
NumericvalueThe analog value that is requested (of type int, short, float, or double).
IntegervariationThe DNP3 object variation to use in the request. [optional]
The DNP3 status code of the response, as an integer.
Example #1
# This example shows setting the analog output at index 0 to the Double value 3.14
system.dnp3.selectOperateAnalog("Dnp3", 0, 3.14)
Example #2
# This example shows setting the analog output at index 2 to the Integer value 300
system.dnp3.selectOperateAnalog("Dnp3", 2, 300)
Example #3
# This example shows setting the analog output at index 15 to the Short value 33. The value sent in the request is converted for the object variation, 2.
system.dnp3.selectOperateAnalog("Dnp3", 15, 33.3333, 2)
Example #4
# This example shows setting the analog output at index 1 to the Float value 15.0. The value sent in the request is converted for the object variation, 3.
system.dnp3.selectOperateAnalog("Dnp3", 1, 15, 3)
