Version: 8.3
system.dnp3.freezeAnalogs
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Issues a freeze command on the given analog outputs.
Permission Type: DNP3 Management
system.dnp3.freezeAnalogs(deviceName, [indexes])
StringdeviceNameThe name of the DNP3 device driver.
ListindexesA list of specific indexes on which to issue the freeze command. An empty list can be passed to freeze all analogs.
Nothing
Example #1
# This example shows a request to freeze all analog inputs in the outstation.
system.dnp3.freezeAnalogs("Dnp3", [])
Example #12
# This example shows a request to freeze analog inputs at indexes 1, 3, and 5.
system.dnp3.freezeAnalogs("Dnp3", [1, 3, 5])
