system.dnp3.directOperateAnalog
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Descriptionβ
Issues a Select-And-Operate command to set an analog value in an analog output point.
Permission Type: DNP3 Management
Syntaxβ
system.dnp3.directOperateAnalog(deviceName, index, value, [variation])
Parametersβ
| String | deviceName | The name of the DNP3 device driver. |
| Integer | index | The index of the object to be modified in the outstation. |
| Numeric | value | The analog value that is requested (of type int, short, float, or double). |
| Integer | variation | The DNP3 object variation to use in the request. |
Returnsβ
Integer - The DNP3 status code of the response, as an integer.
Scopeβ
Code Examplesβ
Example #1
# This example shows setting the analog output at index 0 to the
# Double value 3.14
system.dnp3.directOperateAnalog("Dnp3", 0, 3.14)
Example #2
# This example shows setting the analog output at index 2 to the
# Integer value 300
system.dnp3.directOperateAnalog("Dnp3", 2, 300)
Example #3
# This example shows setting the analog output at index 15 to the
# Short value 33. The value sent in the request is converted
# for the object variation, 2.
system.dnp3.directOperateAnalog("Dnp3", 15, 33.3333, 2)
Example #4
# This example shows setting the analog output at index 1 to the
# Float value 15.0. The value sent in the request is converted
# for the object variation, 3.
system.dnp3.directOperateAnalog("Dnp3", 1, 15, 3)
