system.db.setDatasourceMaxConnections
Descriptionβ
Sets the Max Active and Max Idle parameters of a given database connection.
Permission Type: Datasource Management
Syntaxβ
system.db.setDatasourceMaxConnections(name, maxConnections)
Parametersβ
| String | name | The name of the database connection in Ignition. |
| Integer | maxConnections | Sets the Max Active and Max Idle parameters of a given database connection. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet - Setting the Max Connections of a Data Source
# Example 1: Enable a connection
system.db.setDatasourceMaxConnections("MySQL", 20)
