system.db.setDatasourceEnabled
Descriptionβ
Enables/disables a given database connection.
Permission Type: Datasource Management
Syntaxβ
system.db.setDatasourceEnabled(name, enabled)
Parametersβ
| String | name | The name of the database connection in Ignition. |
| Boolean | enabled | Enables/disables a given database connection. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet - Enabling a Database Connection
# Enable the database named "MySQL"
system.db.setDatasourceEnabled("MySQL", 1)
Code Snippet - Disabling a Database Connection
# Disable the database named "MySQL"
system.db.setDatasourceEnabled("MySQL", 0)
