--- title: "system.db.runScalarPrepQuery" description: "Runs a prepared statement against a database connection just like the runPrepQuery function, but only returns the value from the first row and column." --- # system.db.runScalarPrepQuery > Runs a prepared statement against a database connection just like the runPrepQuery function, but only returns the value from the first row and column. This function is used in **Python Scripting**. ## Description Runs a prepared statement against a database connection just like the [`system.db.runPrepQuery`](appendix\scripting-functions\system-db\system-db-runPrepUpdate.md) function, but only returns the value from the first row and column. If no results are returned from the query, the special value None is returned. ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Legacy Database Access Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax - Gateway `system.db.runScalarPrepQuery(query, args, database, [tx])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `query` | A SQL query (typically a SELECT) to run as a prepared statement with placeholders (?) denoting where the arguments go, that should be designed to return one row and one column. List[Any]| `args` | A list of arguments. Will be used in order to match each placeholder (?) found in the query. String| `database` | The name of the database connection to execute against. String| `tx` | A transaction identifier. If omitted, the query will be executed in its own transaction. [optional] ### Returns **Any** - The value from the first row and first column of the results. Returns None if no rows were returned. ### Scope Gateway ## Syntax - Vision and Perspective `system.db.runScalarPrepQuery(query, args, [database], [tx])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `query` | A SQL query (typically a SELECT) to run as a prepared statement with placeholders (?) denoting where the arguments go, that should be designed to return one row and one column. List[Any]| `args` | A list of arguments. Will be used in order to match each placeholder (?) found in the query. String| `database` | The name of the database connection to execute against. If omitted or "", the project's default database connection will be used. [optional] String| `tx` | A transaction identifier. If omitted, the query will be executed in its own transaction. [optional] ### Returns **Any** - The value from the first row and first column of the results. Returns None if no rows were returned. ### Scope Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Executing Query" # This example searches for the user id of someone based on a typed in username. name = event.source.parent.getComponent("User Search").text result = system.db.runScalarPrepQuery("SELECT user_id FROM users WHERE username = ?", [name]) event.source.parent.getComponent("Text Field").data = result ```
