system.db.runPrepUpdate
Descriptionβ
Runs a prepared statement against the database, returning the number of rows that were affected. Prepared statements differ from regular queries in that they can use a special placeholder, the question-mark character (?), in the query where any dynamic arguments would go, and then use an array of values to provide real information for those arguments. Make sure that the length of your argument array matches the number of question-mark placeholders in your query. This call should be used for UPDATE, INSERT, and DELETE queries.
This is useful for two purposes:
- This method avoids the problematic technique of concatenating user input inside a query, which can lead to syntax errors or a security problem called a SQL injection attack. For example, if you have a user-supplied string in a WHERE clause and you use single-quotes to enclose the string to make the query valid, then the query will fail for users who have single-quotes in their text. Prepared statements are immune to this problem.
- This is the only way to write an INSERT or UPDATE query that has binary or BLOB data. Using BLOBs can be very useful for storing images or reports in the database, where all clients have access to them.
The "?" placeholder refers to variables of the query statement that help the statement return the correct information. The "?" placeholder cannot reference column names, table names, or the underlying syntax of the query. This is because the SQL standard for handling the "?" placeholder excludes these items.
Permission Type: Legacy Database Access
Syntax - Gatewayβ
system.db.runPrepUpdate( query, args, database, [tx], [getKey], [skipAudit])
Parametersβ
| String | query | A query (typically an UPDATE, INSERT, or DELETE) to run as a prepared statement with placeholders (?) denoting where the arguments go. |
| Object[] | args | A list of arguments. Will be used in order to match each placeholder (?) found in the query. |
| String | database | The name of the database connection to execute against. |
| String | tx | Optional, A transaction identifier. If omitted, the update will be executed in its own transaction. [optional] |
| Boolean | getKey | Optional, A flag indicating whether or not the result should be the number of rows returned (getKey=0) or the newly generated key value that was created as a result of the update (getKey=1). Not all databases support automatic retrieval of generated keys. [optional] |
| Boolean | skipAudit | Optional, A flag which, if set to true, will cause the prep update to skip the audit system. Useful for some queries that have fields which won't fit into the audit log. [optional] |
Returnsβ
Integer - The number of rows affected by the query, or the key value that was generated, depending on the value of the getKey flag.
Scopeβ
Gateway
Syntax - Vision and Perspectiveβ
system.db.runPrepUpdate(query, args, [database], [tx], [getKey], [skipAudit])
Parametersβ
| String | database | Optional, The name of the database connection to execute against. If omitted or "", the project's default database connection will be used. [optional] |
Returnsβ
Scopeβ
Vision Client, Perspective Session
Code Examplesβ
# This example gathers some user entered text and inserts it into the database.
userText = event.source.parent.getComponent("TextArea").text
userName = system.security.getUsername()
system.db.runPrepUpdate("INSERT INTO Comments (Name, UserComment) VALUES (?,?)", [userName, userText])
# Unlike the previous example, this example is explicitly declaring which database connection to run the query against.
# Sometimes, you need to run a query against a database connection that is not the default connection.
databaseConnection = "AlternateDatabase"
system.db.runPrepUpdate("INSERT INTO Comments (Name, UserComment) VALUES (?,?)", [userName, userText], databaseConnection)
# This code reads a file and uploads it to the database.
filename = system.file.openFile() # Ask the user to open a file
if filename != None:
filedata = system.file.readFileAsBytes(filename)
system.db.runPrepUpdate("INSERT INTO Files (file_data) VALUES (?)", [filedata])
# This example inserts name, description, and building information into a table called 'machines'. Demonstrates the ability to retrieve a newly created key value.
# Get the name, description, and building information.
name = event.source.parent.getComponent('Name').text
desc = event.source.parent.getComponent('Description').text
building = event.source.parent.getComponent('Building').selectedValue
# Insert the value.
id = system.db.runPrepUpdate("INSERT INTO machines (machine_name, description) VALUES (?, ?)", [name, desc], getKey=1)
# Add a row to the 'machine_building_mapping' table.
system.db.runPrepUpdate("INSERT INTO machine_building_mapping (machine_id, building) VALUES (?, ?)", [id, building])
# This example takes a dataset from a Table component and inserts new records into the database, one row at a time.
# Read the contents of the table.
tableData = event.source.parent.getComponent('Table').data
# Build the query we'll use. You could easily modify this to match the table you're trying to insert into.
query = "INSERT INTO my_table (col1, col2) VALUES (?, ?)"
# Iterate directly over the dataset (no need to convert with toPyDataSet).
for row in tableData:
# Build an arguments list based on the current row.
# 'row[0]' is the 1st column, 'row[1]' is the 2nd column, etc.
args = [row[0], row[1]]
# Add a row to the database. Optionally, you could check the contents of the row
# and add an if-statement to filter which records get inserted.
system.db.runPrepUpdate(query, args)
# Stored Procedures can be called with this function by passing "call <query>", where <query> is the stored procedure.
query="call public.decimal_insert(?)",
args = [10],
database="POSTGRESQL"
