Version: 8.3
system.db.rollbackTransaction
Performs a rollback on the given connection. This will make all statements executed against this transaction since its beginning or since the last commit or rollback undone.
If you are done with the transaction, you must also close it after you do a rollback on it.
system.db.rollbackTransaction(tx)
StringtxThe transaction ID.
Nothing
Python - Rollback a Transaction on an Exception
# This example uses a for-loop to run multiple queries in a single Transaction, and rollback if an error occurs.
# Create some variables for use later.
txId = system.db.beginTransaction(timeout=5000)
status=2
query = "UPDATE MachineStatus SET status=? WHERE ID=?"
errors = False # A flag to denote if we ran into a problem with a query during the transaction.
for machineId in range(8):
try:
system.db.runPrepUpdate(query, args=[status, machineId], tx=txId)
except:
errors = True
break
# If we encountered an error...
if errors:
# ...then rollback the transaction
system.db.rollbackTransaction(txId)
else:
# Otherwise, commit it.
system.db.commitTransaction(txId)
# In either case, close the transaction when we're done.
system.db.closeTransaction(txId)
