system.db.removeDatasource
Descriptionβ
Removes a database connection from Ignition.
Permission Type: Datasource Management
Syntaxβ
system.db.removeDatasource(name)
Parametersβ
| String | name | The name of the database connection in Ignition. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet - Removing Database from Gateway
# This results in the connection named MySQL being removed.
system.db.removeDatasource("MySQL")
