--- title: "system.db.getConnections" description: "Returns a dataset of information about each configured database connection. Each row represents a single connection." --- # system.db.getConnections > Returns a dataset of information about each configured database connection. Each row represents a single connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.db.getConnections()` ### Parameters None ### Returns **Dataset** - A dataset, where each row represents a database connection.The dataset contains the following: | Column Name | Description | | ----------------- | ---------------------------------------------------------------------------------------------------------------------------------- | | Name | Returns the name of this data source. | | Description | Returns the description for this data source. | | DBType | Returns the database connection type. Example types include PostgreSQL, MSSQL, and Oracle. | | Status | Returns the status of this data source based on its last tested condition. Typical values include Valid, Faulted, and Reconnecting. | | Problem | Returns a string describing the current problem, if the status is not good. | | ExtStatus | Returns the "best" status of this data source or of any failover data sources. | | Throughput | Returns number of queries per second, including Insert and Select queries. Throughput will be -1 if idle. | | ActiveConnections | Returns the current number of connections in use. | | MaxConnections | Returns the maximum number of connections the underlying pool is configured to use. | | ValidationQuery | Returns a SQL query that will be used to validate the status of this data source. This query should always return at least 1 row. | ### Scope Gateway, Vision Client, Perspective Session ## Code Examples There are no code examples available for this function.
