Version: 8.3
system.db.getConnections
Returns a dataset of information about each configured database connection. Each row represents a single connection.
system.db.getConnections()
None
Dataset - A dataset, where each row represents a database connection.The dataset contains the following:
Column NameDescription
NameReturns the name of this data source.
DescriptionReturns the description for this data source.
DBTypeReturns the database connection type. Example types include PostgreSQL, MSSQL, and Oracle.
StatusReturns the status of this data source based on its last tested condition. Typical values include Valid, Faulted, and Reconnecting.
ProblemReturns a string describing the current problem, if the status is not good.
ExtStatusReturns the "best" status of this data source or of any failover data sources.
ThroughputReturns number of queries per second, including Insert and Select queries. Throughput will be -1 if idle.
ActiveConnectionsReturns the current number of connections in use.
MaxConnectionsReturns the maximum number of connections the underlying pool is configured to use.
ValidationQueryReturns a SQL query that will be used to validate the status of this data source. This query should always return at least 1 row.
There are no code examples available for this function.
