system.db.getConnectionInfo
Descriptionβ
Returns a dataset of information about a single database connection, as specified by the name argument.
Syntaxβ
system.db.getConnectionInfo(name)
Parametersβ
| String | name | The name of the database connection to find information about. Will use the current project's default database connection if a name is not specified. |
Returnsβ
Dataset - A dataset containing information about the named database connection, or an empty dataset if the connection wasn't found. If a populated dataset is returned, the following data will be given:
| Column Name | Description |
| Name | Returns the name of this data source. |
| Description | Returns the description for this data source. |
| DBType | Returns the database connection type. Example types include PostgreSQL, MSSQL, and Oracle. |
| Status | Returns the status of this data source based on its last tested condition. Typical values include Valid, Faulted, and Reconnecting. |
| Problem | Returns a string describing the current problem, if the status is not good. |
| ExtStatus | Returns the "best" status of this data source or of any failover data sources. |
| Throughput | Returns number of queries per second, including Insert and Select queries. Throughput will be -1 if idle. |
| ActiveConnections | Returns the current number of connections in use. |
| MaxConnections | Returns the maximum number of connections the underlying pool is configured to use. |
| ValidationQuery | Returns a SQL query that will be used to validate the status of this data source. This query should always return at least 1 row. |
Scopeβ
note
The database connection used when called from the Gateway scope is the connection configured on the Gateway scripting project.
Code Examplesβ
Code Snippet - Getting Database Connection Information
# This example checks the database connection type and selects a query format that matches.
connectionInfo = system.db.getConnectionInfo()
dbType = connectionInfo.getValueAt(0, "DBType")
if dbType == "MYSQL":
# mysql format for a column with a space in the name
query = "SELECT `amps value` FROM pumps"
else:
# mssql format for a column with a space in the name
query = "SELECT [amps value] FROM pumps"
