--- title: "system.db.execUpdateAsync" description: "Executes an update query through the Store and Forward system." --- # system.db.execUpdateAsync > Executes an update query through the Store and Forward system. This function is used in **Python Scripting**. ## Description Executes an update query from a Named Query resource through the Store and Forward system. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.db.execUpdateAsync(path, [parameters], [project])` ### Parameters |Type | Parameter | Description |------- | ------- | ----- |String| `path` | The full path of the Named Query.| |Dictionary | `parameters` | A dictionary of parameters for the query. [optional]| |String| `project` | A project name that the query exists in. [optional] **Note**: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used.| ### Returns **Boolean** - Returns a boolean flag indicating of `True` if successfully sent to the Store and Forward system. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Simple Example" # This example runs a Named Query in the Gateway scope. # Request the Named Query to execute. system.db.execUpdateAsync("folderName/myNamedQuery", "ProjectName") ```
