--- title: "system.db.execUpdate" description: "Executes an update query from a Named Query resource." --- # system.db.execUpdate > Executes an update query from a Named Query resource. This function is used in **Python Scripting**. ## Description Executes an update query from a Named Query resource. If the Named Query is through a Store and Forward system, use [system.db.execUpdateAsync](appendix\scripting-functions\system-db\system-db-execUpdateAsync.md) instead. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.db.execUpdate(path, [parameters], [tx], [getKey], [project])` ### Parameters |Type | Parameter | Description |------- | ------- | ----- |String| `path` | The full path of the Named Query.| |Dictionary | `parameters` | A dictionary supplying parameters for the query. [optional]| |String| `tx` | A transaction ID, obtained from `[beginNamedQueryTransaction](appendix/scripting-functions/system-db/system-db-beginNamedQueryTransaction.md)`. If not specified, will not be part of a transaction. [optional]| |Boolean| `getKey` | If True, the primary key of the row inserted or updated in an update query will be returned. Default value is False. [optional]| |String| `project` | A project name that the query exists in. [optional] **Note**: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used.| ### Returns **Integer** - The result of the query. The result will be either the number of rows affected or the key value that was generated, depending on the value of the `getKey` parameter. ### Scope Gateway, Vision Client, Perspective Session ## Code Example ```python title="Simple Example" # This example runs a Named Query without any optional parameters in the Project scope. # Request the Named Query to execute. system.db.execUpdate("folderName/myNamedQuery") ```
