system.db.execUpdate
Descriptionβ
Executes an update query from a Named Query resource. If the Named Query is through a Store and Forward system, use system.db.execUpdateAsync instead.
Syntaxβ
system.db.execUpdate(path, [parameters], [tx], [getKey], [project])
Parametersβ
| String | path | The full path of the Named Query. |
| Dictionary | parameters | A dictionary supplying parameters for the query. [optional] |
| String | tx | A transaction ID, obtained from [beginNamedQueryTransaction](appendix/scripting-functions/system-db/system-db-beginNamedQueryTransaction.md). If not specified, will not be part of a transaction. [optional] |
| Boolean | getKey | If True, the primary key of the row inserted or updated in an update query will be returned. Default value is False. [optional] |
| String | project | A project name that the query exists in. [optional] Note: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used. |
Returnsβ
Integer - The result of the query. The result will be either the number of rows affected or the key value that was generated, depending on the value of the getKey parameter.
Scopeβ
Code Exampleβ
Simple Example
# This example runs a Named Query without any optional parameters in the Project scope.
# Request the Named Query to execute.
system.db.execUpdate("folderName/myNamedQuery")
