system.db.execScalar
Descriptionβ
Executes a scalar query from a Named Query resource.
Syntaxβ
system.db.execScalar(path, [parameters], [tx], [project])
Parametersβ
| String | path | The full path of the named query. |
| Dictionary | parameters | A dictionary of parameters for the query. [optional] |
| String | tx | A transaction ID, obtained from beginNamedQueryTransaction. If not specified, will not be part of a transaction. [optional] |
| String | project | A project name that the query exists in. [optional] Note: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used. |
Returnsβ
Any - The scalar result of the query, as either a single value or None if no rows were returned.
Scopeβ
Code Examplesβ
Simple Example - Without Parameters
# This example runs without any of the optional parameters in the Project scope.
# Request the Named Query to execute.
system.db.execScalar("folderName/myNamedQuery")
Gateway Scope Example
# This example runs a Named Query without the optional parameters in the Gateway scope.
system.db.execScalar("folderName/myNamedQuery", "ProjectName")
