Version: 8.3
system.db.execQuery
Executes a select query from a Named Query resource.
system.db.execQuery(path, [parameters], [tx], [project])
StringpathThe full path of the named query.
DictionaryparametersA dictionary of parameters for the query. [optional]
StringtxA transaction ID, obtained from beginNamedQueryTransaction. If not specified, will not be part of a transaction. [optional]
StringprojectA project name that the query exists in. [optional]
Note: If no project is specified when run in the Gateway scope, an associated project or the Gateway scripting project will be used.
Dataset - The result of the query.
Simple Example - Without Parameters
# This example runs without any of the optional parameters in the Project scope.
# Request the Named Query to execute.
system.db.execQuery("folderName/myNamedQuery")
Gateway Scope Example
# This example runs a Named Query without the optional parameters in the Gateway scope.
system.db.execQuery("folderName/myNamedQuery", "ProjectName")
