--- title: "system.db.addDatasource" description: "Adds a new database connection in Ignition." --- # system.db.addDatasource > Adds a new database connection in Ignition. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Datasource Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.addDatasource(jdbcDriver, name, description, [connectUrl], [username], [password], [props], [validationQuery], [maxConnections])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String | `jdbcDriver` | The name of the JDBC driver configuration to use. Available options are based off the JDBC driver configurations on the the Gateway. String | `name` | The data source name. String | `description` | Description of the data source. [optional] String | `connectUrl` | Default is the connect URL for JDBC driver. [optional] String | `username` | Username to login to the data source with. [optional] String | `password` | Password for the login. [optional] String | `props` | The extra connection parameters. [optional] String | `validationQuery` | Default is the validation query for the JDBC driver. [optional] Integer | `maxConnections` | Default is 8. [optional] ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Adding a MySQL Database to a Gateway" system.db.addDatasource(jdbcDriver="myJDBCDriver", name="NewDatabase", connectURL="jdbc:mysql://localhost:3306/test", username="root", password="password", props="zeroDateTimeBehavior=convertToNull;") ```
