system.db.addDatasource
Descriptionβ
Adds a new database connection in Ignition.
Permission Type: Datasource Management
Syntaxβ
system.db.addDatasource(jdbcDriver, name, description, [connectUrl], [username], [password], [props], [validationQuery], [maxConnections])
Parametersβ
| String | jdbcDriver | The name of the JDBC driver configuration to use. Available options are based off the JDBC driver configurations on the the Gateway. |
| String | name | The data source name. |
| String | description | Description of the data source. [optional] |
| String | connectUrl | Default is the connect URL for JDBC driver. [optional] |
| String | username | Username to login to the data source with. [optional] |
| String | password | Password for the login. [optional] |
| String | props | The extra connection parameters. [optional] |
| String | validationQuery | Default is the validation query for the JDBC driver. [optional] |
| Integer | maxConnections | Default is 8. [optional] |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet - Adding a MySQL Database to a Gateway
system.db.addDatasource(jdbcDriver="myJDBCDriver", name="NewDatabase",
connectURL="jdbc:mysql://localhost:3306/test", username="root",
password="password", props="zeroDateTimeBehavior=convertToNull;")
