--- title: "system.date.format" description: "Returns the given date as a string and formatted according to a pattern." --- # system.date.format > Returns the given date as a string and formatted according to a pattern. This function is used in **Python Scripting**. ## Description Returns the given date as a string and formatted according to a pattern. The pattern is a format that is full of various placeholders that display different parts of the date. These are case-sensitive. These placeholders can be repeated for a different effect. For example, M will give you 1-12, MM will give you 01-12, MMM will give you Jan-Dec, MMMM will give you January-December. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.date.format(date, format)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Date | `date` | The date to format. String | `format` | A format string such as "yyyy-MM-dd HH:mm:ss". The format argument is optional. The default is "yyyy-MM-dd HH:mm:ss". Refer to [Data Type Formatting Reference](appendix\reference-pages\data-type-formatting-reference\data-type-formatting-reference.md) for a table of acceptable symbols. ### Returns **String** - A string representing the formatted datetime. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example would format the current date to look like "01/01/01" today = system.date.now() print system.date.format(today, "yy/MM/dd") #This printed 16/04/01 ``` ```python title="Example #2" # This example would format the current date to look like "2001-01-31 16:59:59" # This is a standard format that all databases recognize. today = system.date.now() print system.date.format(today, "yyyy-MM-dd HH:mm:ss") ```
