system.date.format
Descriptionβ
Returns the given date as a string and formatted according to a pattern. The pattern is a format that is full of various placeholders that display different parts of the date. These are case-sensitive. These placeholders can be repeated for a different effect. For example, M will give you 1-12, MM will give you 01-12, MMM will give you Jan-Dec, MMMM will give you January-December.
Syntaxβ
system.date.format(date, format)
Parametersβ
| Date | date | The date to format. |
| String | format | A format string such as "yyyy-MM-dd HH:mm:ss". The format argument is optional. The default is "yyyy-MM-dd HH:mm:ss". Refer to Data Type Formatting Reference for a table of acceptable symbols. |
Returnsβ
String - A string representing the formatted datetime.
Scopeβ
Code Examplesβ
Example #1
# This example would format the current date to look like "01/01/01"
today = system.date.now()
print system.date.format(today, "yy/MM/dd")
#This printed 16/04/01
Example #2
# This example would format the current date to look like "2001-01-31 16:59:59"
# This is a standard format that all databases recognize.
print system.date.format(today, "yyyy-MM-dd HH:mm:ss")
