Version: 8.3
system.config.replace
New in 8.3.8
Replaces an existing resource completely with a new configuration. The resource must already exist.
system.config.replace(*moduleId, typeId, [name], [collection], signature, [config], [backupConfig], [files], [description], [enabled], [attributes], [actor])
tip
An asterisk indicates that all parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, both the parameter and argument must be specified. For example, moduleId="ignition".
String*moduleIdThe module ID portion of the resource type identifier.
String*typeIdThe type ID portion of the resource type identifier.
String*nameThe name of the resource. Required for named resources, but must be omitted for singleton resources. [Optional]
String*collectionThe collection containing the resource. If omitted, uses the active definition. [Optional]
String*signatureThe hex-encoded signature of the resource.
Dictionary*configA dictionary representing the resoure configuration, matching the resource type's JSON schema. If not provided, the files argument must be provided. [Optional]
Dictionary*backupConfigA dictionary representing the backup configuration for resources that support backup data. [Optional]
Dictionary*filesA dictionary of additional files to include with the resource. Keys are filenames, values can be byte arrays, strings, lists, or dictionaries. If not provided, the config argument must be provided. [Optional]
String*descriptionA description for the resource. [Optional]
Boolean*enabledWhether the replacement resource should be enabled. If omitted, the resource will be in the same state after its configuration is replaced. [Optional]
Dictionary*attributesA dictionary of resource attributes to set. [Optional]
String*actorA string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional]
PyResource - The newly configured resource, as a PyResource that can also be read as plain Python properties.
Gateway
Code Snippet
# This example will replace our existing "MySQL" database connection configuration with a configuration that
# uses a different schema in the Connect URL and "Sticky" Failover Mode.
# Get the required signature using getResource()
# Declare required variables for getResource()
moduleId = "ignition"
typeId = "database-connection"
name = "MySQL"
myResource = system.config.getResource(moduleId=moduleId, typeId=typeId, name=name)
signature = myResource.signature
# Use the information we got for the replace() function
# Declare the rest of the required variables for replace()
config = {
"connectURL": "jdbc:mysql://localhost:3306/devDB",
"connectionProps": "zeroDateTimeBehavior\u003dCONVERT_TO_NULL;connectTimeout\u003d120000;socketTimeout\u003d120000;useSSL\u003dfalse;allowPublicKeyRetrieval\u003dtrue;rewriteBatchedStatements\u003dtrue;disableMariaDbDriver",
"connectionResetParams": "",
"defaultTransactionLevel": "DEFAULT",
"driver": "MySQL",
"evictionRate": -1,
"evictionTests": 3,
"evictionTime": 1800000,
"failoverMode": "STICKY",
"failoverProfile": "",
"includeSchemaInTableName": false,
"poolInitSize": 0,
"poolMaxActive": 8,
"poolMaxIdle": 8,
"poolMaxWait": 5000,
"poolMinIdle": 0,
"slowQueryLogThreshold": 60000,
"testOnBorrow": true,
"testOnReturn": false,
"testWhileIdle": false,
"translator": "MYSQL",
"username": "root",
"validationQuery": "SELECT 1",
"validationSleepTime": 10000
# Call the replace() function
system.config.replace(moduleId=moduleId, typeId=typeId, name=name, signature=signature, config=config)
