--- title: "system.config.rename" description: "Renames the specified resource." --- # system.config.rename > Renames the specified resource. This function is used in **Python Scripting**. ## Description Renames the specified resource within its current collection. Use the [move()](appendix\scripting-functions\system-config\system-config-move.md) function to transfer resources between collections. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.config.rename(*moduleId, typeId, [name], [collection], newName, [references], [actor])` :::tip An asterisk indicates that **all** parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, **both** the parameter and argument **must** be specified. For example, `moduleId="ignition"`. ::: ### Parameters | Type | Parameter | Description | |---|---|---| | String | *moduleId | The module ID portion of the resource type identifier. | | String | *typeId | The type ID portion of the resource type identifier. | | String | *name | The name of the resource. Required for [named](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#named-resources) resources, but must be omitted for [singleton](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#singleton-resources) resources. [Optional] | | String | *collection | The [collection](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#collections) containing the resource. If omitted, uses the active definition. [Optional] | | String | *newName | The new name for the resource. | | String | *references | How Ignition should handle references from other resources to the current value of the resource that is being renamed. Valid options are: ABORT: Aborts the renaming operation.UPDATE: Updates resources to use the new resource name.IGNORE: Ignores any references to the old name and proceeds with the renaming operation. [Optional] | | String | *actor | A string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional] | ### Returns **PyResource** - The resource that was renamed, as a PyResource that can also be read as plain Python properties. ### Scope Gateway ## Code Examples ```python title="Code Snippet" # This example renames an existing database connection called "MySQL" to "coolSQL". # Declare our parameter variables moduleId = "ignition" typeId = "database-connection" name = "MySQL" newName = "coolSQL" # Call the rename() function system.config.rename(moduleId=moduleId, typeId=typeId, name=name, newName=newName) ```
