--- title: "system.config.move" description: "Moves a resource to a different collection." --- # system.config.move > Moves a resource to a different collection. This function is used in **Python Scripting**. ## Description Moves a resource to a different collection. The move operation changes which collection a resource belongs to, but does not allow renaming. Use the [rename()](appendix\scripting-functions\system-config\system-config-rename.md) operation to change a resource's name. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.config.move(*moduleId, typeId, [name], [collection], newCollection, signature, [actor])` :::tip An asterisk indicates that **all** parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, **both** the parameter and argument **must** be specified. For example, `moduleId="ignition"`. ::: ### Parameters | Type | Parameter | Description | |---|---|---| | String | *moduleId | The module ID portion of the resource type identifier. | | String | *typeId | The type ID portion of the resource type identifier. | | String | *name | The name of the resource. Required for [named](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#named-resources) resources, but must be omitted for [singleton](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#singleton-resources) resources. [Optional] | | String | *collection | The [collection](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#collections) containing the resource. If omitted, uses the active definition. [Optional] | | String | *newCollection | The new collection for the resource to move to. | | String | *signature | The hex-encoded signature of the resource. | | String | *actor | A string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional] | ### Returns **PyResource** - The Gateway resource that was moved, which can also be read as plain Python properties. ### Scope Gateway ## Code Examples ```python title="Code Snippet" # This example takes an existing database connection and moves to into a collection called "dev". # Use the getResource() function to retrieve the resource signature moduleId = "ignition" typeId = "database-connection" name = "MySQL" myResource = system.config.getResource(moduleId=moduleId, typeId=typeId, name=name) newCollection = "dev" signature = myResource.signature system.config.move(moduleId=moduleId, typeId=typeId, name=name, newCollection=newCollection, signature=signature) ```
