Version: 8.3
system.config.getResources
New in 8.3.8
Returns all resources of the specified type.
system.config.getResources(*moduleId, typeId)
tip
An asterisk indicates that all parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, both the parameter and argument must be specified. For example, moduleId="ignition".
StringmoduleIdThe module ID portion of the resource type identifier.
StringtypeIdThe type ID portion of the resource type identifier.
List - A List of all the resources of the specified type, as a PyResource.
Gateway
Code Snippet
# This example will return all available database connections on the Gateway and
# print them to a label on the same view.
moduleId = "ignition"
typeId = "database-connection"
allDBConnections = system.config.getResources(moduleId = moduleId, typeId = typeId)
self.getSibling("Label").props.text = str(allDBConnections)
