--- title: "system.config.getActiveMode" description: "Returns the currently active resource collection mode, or None if no mode is explicitly active." --- # system.config.getActiveMode > Returns the currently active resource collection mode, or None if no mode is explicitly active. This function is used in **Python Scripting**. ## Description Returns the current [deployment mode](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#deployment-modes), or None if no mode is explicitly active. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.config.getActiveMode()` ### Parameters Nothing ### Returns **String** - The active collection, as a string. ### Scope Gateway ## Code Examples ```python title="Code Snippet" # This example will return the active collection and print it to a label component on the same view. activeCollection = system.config.getActiveMode() self.getSibling("Label").props.text = activeCollection ```
