--- title: "system.config.delete" description: "Deletes a resource of the specified type." --- # system.config.delete > Deletes a resource of the specified type. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.config.delete(*moduleId, typeId, [name], [collection], signature, [force], [actor])` :::tip An asterisk indicates that **all** parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, **both** the parameter and argument **must** be specified. For example, `moduleId="ignition"`. ::: ### Parameters | Type | Parameter | Description | |---|---|---| | String | *moduleId | The module ID portion of the resource type identifier. | | String | *typeId | The type ID portion of the resource type identifier. | | String | *name | The name of the resource. Required for [named](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#named-resources) resources, but must be omitted for [singleton](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#singleton-resources) resources. [Optional] | | String | *collection | The [collection](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#collections) containing the resource. If omitted, uses the active definition. [Optional] | | String | *signature | The hex-encoded signature of the resource. | | Boolean | *force | If true, deletes the resource even if other resources reference it. If omitted, default is false. [Optional] | | String | *actor | A string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional] | ### Returns Nothing ### Scope Gateway ## Code Examples ```python title="Code Snippet" # This example deletes a specified database connection resource. # Get the required signature argument from your resource using system.config.getResource() moduleId = "ignition" typeId = "database-connection" name = "coolSQL" # Use the getResource() function myResource = system.config.getResource(moduleId=moduleId, typeId=typeId, name=name) # Declare the resource signature variable signature = myResource.signature # Use the delete() function system.config.delete(moduleId=moduleId, typeId=typeId, name=name, signature=signature) ```
