--- title: "system.config.copy" description: "Copies a resource to a new name and/or collection. When using this function, either the newName or newCollection parameter must be defined." --- # system.config.copy > Copies a resource to a new name and/or collection. When using this function, either the newName or newCollection parameter must be defined. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.config.copy(*moduleId, typeId, [name], [collection], [newName], [newCollection], signature, [actor])` :::tip An asterisk indicates that **all** parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, **both** the parameter and argument **must** be specified. For example, `moduleId="ignition"`. ::: ### Parameters | Type | Parameter | Description | |---|---|---| | String | *moduleId | The module ID portion of the resource type identifier. | | String | *typeId | The type ID portion of the resource type identifier. | | String | *name | The name of the resource. Required for [named](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#named-resources) resources, but must be omitted for [singleton](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#singleton-resources) resources. [Optional] | | String | *collection | The [collection](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#collections) containing the resource. If omitted, uses the active definition. [Optional] | | String | *newName | The new name for the copied resource. Required if not changing collection for named resource types. [Optional] | | String | *newCollection | The new collection for the copied resource. Required if not changing name for singleton resource types. [Optional] | | String | *signature | The hex-encoded signature of the resource. | | String | *actor | A string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional] | ### Returns **PyResource** - A PyResource containing the specified parameter attributes of an existing Gateway resource, which can also be read as plain Python properties. ### Scope Gateway ## Code Examples ```python title="Code Snippet" # This example takes a database connection from the core collection and # copies it into a collection called "dev". # Get the required signature argument from your resource using system.config.getResource() moduleId = "ignition" typeId = "database-connection" name = "MySQL" # Use the getResource() function myResource = system.config.getResource(moduleId=moduleId, typeId=typeId, name=name) # Declare the new collection location variable and the resource signature newCollection = "dev" signature = myResource.signature # Use the copy() function system.config.copy(moduleId=moduleId, typeId=typeId, name=name, newCollection=newCollection, signature=signature) ```
