Version: 8.3
system.config.copy
New in 8.3.8
Copies a resource to a new name and/or collection. When using this function, either the newName or newCollection parameter must be defined.
system.config.copy(*moduleId, typeId, [name], [collection], [newName], [newCollection], signature, [actor])
tip
An asterisk indicates that all parameters following it are expecting keywords when the function is being called in your script. This means that, when using an asterisk-marked parameter, both the parameter and argument must be specified. For example, moduleId="ignition".
String*moduleIdThe module ID portion of the resource type identifier.
String*typeIdThe type ID portion of the resource type identifier.
String*nameThe name of the resource. Required for named resources, but must be omitted for singleton resources. [Optional]
String*collectionThe collection containing the resource. If omitted, uses the active definition. [Optional]
String*newNameThe new name for the copied resource. Required if not changing collection for named resource types. [Optional]
String*newCollectionThe new collection for the copied resource. Required if not changing name for singleton resource types. [Optional]
String*signatureThe hex-encoded signature of the resource.
String*actorA string identifying the actor performing the operation. If not specified, an identifier will be automatically generated. [Optional]
PyResource - A PyResource containing the specified parameter attributes of an existing Gateway resource, which can also be read as plain Python properties.
Gateway
Code Snippet
# This example takes a database connection from the core collection and
# copies it into a collection called "dev".
# Get the required signature argument from your resource using system.config.getResource()
moduleId = "ignition"
typeId = "database-connection"
name = "MySQL"
# Use the getResource() function
myResource = system.config.getResource(moduleId=moduleId, typeId=typeId, name=name)
# Declare the new collection location variable and the resource signature
newCollection = "dev"
signature = myResource.signature
# Use the copy() function
system.config.copy(moduleId=moduleId, typeId=typeId, name=name, newCollection=newCollection, signature=signature)
