--- title: "system.bacnet.synchronizeTimeUtc" description: "Notifies the remote device of the correct current time in UTC." --- # system.bacnet.synchronizeTimeUtc > Notifies the remote device of the correct current time in UTC. This function is used in **Python Scripting**. ## Description :::note To use this function, the [BACnet](ignition-modules\opc-ua\opc-ua-drivers\bacnet\bacnet.md) driver must be installed. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.bacnet.synchronizeTimeUtc(deviceName)` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `deviceName` | The name of the configured BACnet/IP device instance to write from. ### Returns Nothing ### Scope Gateway, Perspective Session ## Code Example ```python title="Code Snippet - Basic Usage" deviceName = "BACnet Remote" system.bacnet.synchronizeTimeUtc(deviceName) ```
