--- title: "system.alarm.unshelve" description: "Unshelves a list of alarms based on the source paths provided." --- # system.alarm.unshelve > Unshelves a list of alarms based on the source paths provided. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md): Alarm Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.alarm.unshelve(path)` ### Parameters Type | Parameter | Description ------- | ------- | ------- List[String] | `path` | A list of possible source paths to search at. If a path ends in "/*", the results will include anything below that path. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Unshelve an Alarm at a Path testPath = "prov:TAG_PROVIDER_NAME:/tag:TAG_PATH:/alm:ALARM_NAME" system.alarm.unshelve(path= [testPath]) ```
