system.alarm.shelve
Descriptionβ
This function shelves the specified alarms for the specified amount of time. The time can be specified in minutes (timeoutMinutes) or seconds (timeoutSeconds). If an alarm is already shelved, this will overwrite the remaining time. If no timeout is specified, will default to 15 minutes.
Client Permission: Alarm Management
Syntaxβ
system.alarm.shelve(path, [timeoutSeconds], [timeoutMinutes])
Parametersβ
| List[String] | path | A list of possible source paths to search at. If a path ends in "/*", the results will include anything below that path. |
| Integer | timeoutSeconds | The amount of time to shelve the matching alarms for, specified in seconds. Setting this to 0 will unshelve the alarms. [optional] |
| Integer | timeoutMinutes | The amount of time to shelve the matching alarms for, specified in minutes. Setting this to 0 will unshelve the alarms. [optional] |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Example #1
# This example assumes that data has been loaded into a table ("Table") from system.alarm.queryStatus, and it shelves the selected alarms for 5 minutes.
# It also assumes that it is being executed from a button's actionPerformed event.
table = event.source.parent.getComponent('Table')
rows = table.selectedRows
data = table.data
if len(rows)>0:
sourcePaths = [str(data.getValueAt(r,'Source')) for r in rows]
system.alarm.shelve(path=sourcePaths,timeoutMinutes=5)
