--- title: "system.alarm.queryStatus" description: "Queries the current state of alarms. The result is a list of alarm events, which can be queried for individual properties." --- # system.alarm.queryStatus > Queries the current state of alarms. The result is a list of alarm events, which can be queried for individual properties. This function is used in **Python Scripting**. ## Description Queries the current state of alarms. The result is a list of alarm events, which can be parsed for individual properties. The results provided by this function represent the current state of alarms, in contrast to the historical alarm events retrieved by the [system.alarm.queryJournal](appendix\scripting-functions\system-alarm\system-alarm-queryJournal.md) function. :::note Depending on the number of alarm events in the system, this function can be fairly intensive and take a while to finish executing. This can be problematic if the application is attempting to show the results on a component (such as using this function to retrieve a count of alarms). In these cases it's preferred to call this function in a gateway script of some sort (such as a [timer script](platform/scripting/scripting-in-ignition/gateway-event-scripts/gateway-event-scripts.md#timer-script)), and store the results in a tag. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md) restrictions. ## Syntax `system.alarm.queryStatus([priority], [state], [path], [source], [displaypath], [all_properties], [any_properties], [defined], [includeShelved], [provider])` ### Parameters Type | Parameter | Description ------- | ------- | ------- List[Integer / String] | `priority` | A list of possible priorities to match. Priorities can be specified by name or number, with the values: Diagnostic(0), Low(1), Medium(2), High(3), Critical(4). [optional] List[Integer / String] | `state` | A list of states to allow. See [State Values](#state-parameter-values) for a list of options. [optional] List[String] | `path` | A list of possible source paths to search at. The wildcard "*" may be used. Works the same as the source argument, and either can be used. [optional] List[String] | `source` | A list of possible source paths to search at. The wildcard "*" may be used. Works the same as the path argument, and either can be used. [optional] List[String] | `displaypath` | A list of display paths to search at. Display paths are separated by "/", and if a path ends in "/*", everything below that path will be searched as well. [optional] List[Tuple[String, String, Any] | `all_properties` | A set of property conditions, all of which must be met for the condition to pass. This parameter is a list of tuples, in the form ("propName", "condition", value). Valid propName values can be either associated data or the keys listed on the [PyAlarmEvent object](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#pyalarmevent). Valid condition values: `=`,`!=`,`<`,`<=`,`>`,`>=`. String values can only be compared using `=` and `!=` conditions. [optional] List[Tuple[String, String, Any] | `any_properties` | A set of property conditions, any of which will cause the overall condition to pass. This parameter is a list of tuples, in the form ("propName", "condition", value). Valid propName values can be either associated data or the keys listed on the [PyAlarmEvent object](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#pyalarmevent). Valid condition values: `=`,`!=`,`<`,`<=`,`>`,`>=`. String values can only be compared using `=` and `!=` conditions. [optional] List[String] | `defined` | A list of string property names, all of which must be present on an event for it to pass. [optional] Boolean | `includeShelved` | A flag indicating whether shelved events should be included in the results. Defaults to false. [optional] List[String] | `provider` | A list of tag providers to include in the query. Omitting this parameter will query all providers. [optional] ### Returns **AlarmQueryResult** - The AlarmQueryResult object is a list of PyAlarmEvent objects with some additional helper methods, see [Scripting Object Reference](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md). Additionally, each PyAlarmEvent inside of the AlarmQueryResult object has several built-in methods to extract alarm information. More details on these methods can be found on the [Scripting Object Reference](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md) page. :::note Each item in the resulting list is a combination of each alarm event for the same alarm: details for when the alarm became active, acknowledged, and cleared are combined into a single item. This differs from [system.alarm.queryJournal()](appendix\scripting-functions\system-alarm\system-alarm-queryJournal.md) which splits these events into separate items ::: ### Scope Gateway, Vision Client, Perspective Session ### State Parameter Values |String Representation |Integer Representation | |---|---| |ClearUnacked |0 | |ClearAcked |1 | |ActiveUnacked |2 | |ActiveAcked |3 | ## Code Examples ```python title="Example #1" # This example queries the state of all tags named "HiAlarm", and puts the results in a Vision table Component named "Table" (this assumes it's being run from a button on the same screen) # Note that this example is simple for the sake of brevity. Normally you'll want to use system.util.invokeAsynchronous to search for alarms in a separate thread, especially so if calling # this function from a component based script. See the next example for more information. table = event.source.parent.getComponent("Table") results = system.alarm.queryStatus(source=["*HiAlarm*"]) table.data = results.getDataset() ``` ```python title="Example #2" # In this example we'll call system.alarm.queryStatus in a separate thread, and return the results # to the data property on a Vision Table component. This prevents the Vision Client from freezing # if queryStatus takes a long time to return. # Define a function that will retrieve alarm data in a separate thread def getAlarms(): # Call queryStatus to retrieve alarm data that contains the word "Sensor" in the source path. results = system.alarm.queryStatus(source=["*Sensor*"]) # Define a function to update the GUI. We pull the dataset out of results # since the Vision Table component expects a dataset. def setTheTable(alarms=results.getDataset()): event.source.parent.getComponent("Table").data = alarms # Use invokeLater (system.vision) to update the GUI thread safely. system.vision.invokeLater(setTheTable) # Start the process in a background thread system.util.invokeAsynchronous(getAlarms) ``` ```python title="Example #3" # The any_properties parameter allows you to filter the results for specific properties. This is useful when searching for alarms that contain associated data. # Build a List of Tuples that represent the properties to search for. In this case, if our alarms have an Associated Data named 'Group', we can use # the following to search for potential values props = [("Group", "=", "value1"), ("Group", "=", "value2")] state = ["ActiveUnacked", "ActiveAcked"] alarms = system.alarm.queryStatus(any_properties = props, state = state) # Here we're printing out the number of alarms that meet our criteria. We could replace this and further examine each individual alarm in a for-loop instead. print len(alarms) ``` ```python title="Example #4" # Using all_properties (AND operator) props = [ ("EventId","=","9bb7e0ee-011b-4f37-8e07-e54706e11852"), ("Priority","=","Medium"), ("EventTime", "=", "Jan 04 17:07:12 UTC 2022") ] results = system.alarm.queryStatus(all_properties=props) ```
