--- title: "system.alarm.listPipelines" description: "Will return a list of the available Alarm Notification Pipelines in a project." --- # system.alarm.listPipelines > Will return a list of the available Alarm Notification Pipelines in a project. This function is used in **Python Scripting**. ## Description Will return a list of the available Alarm Notification Pipelines in a project. The order of the returned list is not guaranteed. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.alarm.listPipelines([projectName])` ### Parameters | Type | Parameter | Description | | ------- | ------- | ------- | |String | `projectName` | The project to check alarm pipelines for. If omitted, will look for a project named "alarm-pipelines". [optional] | ### Returns **List[String]** - A list of pipeline names. The list will be empty if no pipelines exist. Unsaved name changes will not be reflected in the list. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This script will print a list of all alarm pipeline names in the current project. project = system.util.getProjectName() pipelines = system.alarm.listPipelines(project) for pipeline in pipelines: print pipeline ``` ```python title="Example #2" # This script will retrieve all pipelines across all projects projects = system.project.getProjectNames() for p in projects: print "Project %s has the following alarm pipelines:" % p pipelines = system.alarm.listPipelines(p) for i in pipelines: print "- %s" % i ```
