Web XML File Reference
Ignition is a Java application that comes with an embedded Java EE servlet container, implemented using the open source Eclipse Jetty library. Aspects of this servlet container can be customized using the web.xml file, which is an open standard configuration file.
Keep in mind that while these attributes can be modified, most installations won't need to change them. If you are interested in changing these attributes, please read through the descriptions thoroughly, and consult with our Support department before proceeding.
Configuration File Locationβ
The web.xml file can be found at:
%IgnitionInstallationDirectory%/webserver/webapps/main/WEB-INF
Web XML Attributesβ
Many of the attributes in the web.xml file are contained within servlet annotations, and denoted using XML tags. Other annotations, such as session-config, context-param, and filter are also used.
The annotations below control some parts of Ignition, but not all. For example, Perspective is tracked using the servlet container session API and thus affected by these annotations, but the Gateway Webpage is not and therefore not subject to these parameters.
session-configβ
| Annotation | Description |
| session-config | Defines the session attributes for the web application. |
| session-timeout | The amount of time in minutes after which the session in the web application expires. |
| cookie-config | Defines the settings for session cookies within the web application. |
| http-only | Prevents client scripts from reading cookies. |
| tracking-mode | Indicates how a user's session is tracked. Default is COOKIE. |
context-paramβ
| context-param | Defines the initialization parameters for the entire web application. |
| param-name | The name to use within the context-param element. |
| param-value | The string value to use within the context-param element. |
filter and filter-mappingβ
| filter | Defines a filter class and the attributes to use when the web application is initializing. |
| filter-mapping | Specifies which URLs or servlets that the filter is to be used on. |
| filter-name | The name of the filter to be mapped to a URL pattern or servlet. The filter-name for both filter and filter-mapping should match. |
| filter-class | The qualified class name of the filter. |
| async-supported | Allows the servlet to store requests to respond to later, giving the thread freedom to continue processing other requests. Default is true. |
| url-pattern | The pattern by which URLs are resolved. |
servlet and servlet-mappingβ
| servlet | The Java program running on a web or application server that handles client and HTTP requests and generates dynamic responses. |
| servlet-mapping | Defines the mapping between a servlet and URL pattern. |
| servlet-name | The name of the servlet that the URL pattern will be mapped to. |
| servlet-class | The qualified class name of the servlet. |
| load-on-startup | Indicates the order in which the servlet should be loaded, with lower values loading before higher values. |
| multipart-config | Enables file uploading capabilities within the web application. With regards to Ignition, this attribute supports the File Upload component. Elements within this attribute include:
