Project Browser Symbol Reference
This reference section provides tables showing the symbols used in Project Browser along with the symbol name and description.
Project Browser Iconsβ
Miscellaneousβ
Scriptingβ
| Symbol | Name | Description |
 | Project Library | Workspace for the Project Library. |
 | Script | Icon for an individual script. Appears next to the name of the script. |
 | Gateway Events | Scripts for events that execute on the Gateway. |
Perspectiveβ
Additional symbols (Badge icons) can show up to the right of these items. See the Perspective Designer Interface page for an explanation.
 | Session Events | Scripts for events that occur during a Perspective Session. |
 | Styles | Styles folder within Perspective. |
 | Views | Views folder within Perspective. |
 | View | Icon for an individual View. Appears next to the name of the View. |
 | Edit View | Edits a View within Perspective. |
Transaction Groupsβ
 | Standard Group | Icon for a block Standard Group. |
 | Standard Group - Disabled | Indicates that capability to create Standard Groups is disabled. |
 | Block Group | Icon for a Block Transaction Group. |
 | Block Group - Disabled | Indicates that capability to create Block Groups is disabled. |
 | Historical Group | Icon for a Historical Group. |
 | Historical Group - Disabled | Indicates that capability to create Historical Groups is disabled. |
 | Stored Procedure Group | Icon for a block Stored Procedure Group. |
 | Stored Procedure Group - Disabled | Indicates that capability to create Stored Procedure Groups is disabled. |
Additional symbols (Badge icons) can show up to the right of these items. See the Vision Designer Interface page for an explanation.
 | Client Events | Scripts for events that execute in Vision Clients. |
 | Windows | Folder for Main, Popup, and Docked windows within the Vision module. |
 | Window | Icon for selecting the Main window option when creating a new view. Appears next to the window name. Also used for Popup and Docked windows after they are created. |
 | Window - Editing | Indicates that this window is currently open for editing. |
 | Popup Window | Icon for selecting the Popup window option when creating a new view. |
 | Docked Window | Icon for selecting the Docked window option when creating a new view. |
 | Templates | Icon for the Template folder. |
 | Vision Template File | Icon for individual Vision Templates. |
 | Vision Templates - Editing | Indicates that this template is currently open for editing. |
Event Streamsβ
 | Event Stream | Icon for individual event streams. |
Named Queriesβ
 | New Query | Create new Named Query. |
 | Named Query - Disabled | Indicates that access to Global resources is disabled. |
 | Named Query - Editing | Icon for an individual Named Query. Clicking opens the Named Query for editing. |
Reportsβ
 | New Report... | Create a new Report. |
 | Report - Disabled | Indicates that capability to create a Report is disabled. |
 | Report - Editing | Icon for an individual report. Clicking opens the report for editing. |
Generalβ
The symbols and options in this section are used for almost all resources in the Project Browser. See the following sections for resource-specific context menu options.
 | Rename | Renames the current selection. |
 | Cut | Cuts the current selection into the clipboard. |
 | Copy | Copies the current selection into the clipboard. |
 | Copy Path | Copies the current path into the clipboard. |
 | Paste | Pastes the content in the clipboard into the selected context. |
 | Delete | Deletes the current selection. |
 | Revert Changes | Reverts any changes made to the resource. Only available if the project has not yet been saved. |
 | Export... | Export the selected resource(s) to a project backup file. |
 | Protect | Locks the individual project resource from inside the Designer. |
 | Documentation | Allows users to add custom documentation to the selected resource. |
 | Find/Replace... | Opens a popup window to allow users to find and replace specified resources. This option is available for the following resources: - Perspective Views
- Transaction Groups
- Vision Windows
- Vision Templates
- Named Queries
Sequential Function Charts (SFC)β
 | Export (XML) | Export the SFC as XML. |
 | Import (XML) | Import an SFC as XML. |
Scriptingβ
 | Close & Commit | Close and commit changes to the Designer's local copy of the project. Available for individual scripts. |
 | Close & Revert | Close and discard all local changes. Reverts the script to what it was when the project was last opened or updated. Available for individual scripts. |
Perspectiveβ
| No Symbol | New Style | Creates a new style class. |
 | New Folder | Creates a new folder for the selected resource. Available for both styles and views. |
 | Enable Advanced Style Sheet | Adds a CSS style sheet to your project. |
 | New View | Creates a new view. |
Transaction Groupsβ
 | New Folder | Creates a new folder. |
 | New Transaction Group | Creates a new Transaction Group. You can create historical, block, standard, and stored procedure groups. |
 | New Item | Adds a new item to the selected Transaction Group. You can add OPC items, expression items, and tag references. |
 | Toggle Pause | Pauses the currently selected and enabled Transaction Group. You can click this option again to unpause the Transaction Group. |
 | Import | Imports Transaction Group data. |
 | Open on Startup | If checked, the selected window will open when the Client starts up. |
 | "About" Window | If checked, this window will be accessible through the Help > About This Application menu in the Client. |
 | Scripting... | Allows users to configure scripts for the selected component, such as event handlers. |
 | Security | Shows security settings for the selected component. |
 | Duplicate | Creates a copy of the selected view or template. |
Event Streamsβ
 | New Event Stream... | Creates a new event stream. |
