--- title: "Ignition Database Table Reference" --- # Ignition Database Table Reference > Ignition has a lot of systems built-in that will query the database automatically without requiring you to build a query. These systems automatically create the necessary tables in the database, insert the relevant data, and even query it back out for you. However, because this data is all stored in simple database tables, it can be manually accessed using queries to customize how you see the data. :::caution These tables are configured in very specific ways. Altering them may cause unforeseen issues, and is not recommended. While it can be useful to manually query out data from these tables, we recommend taking a backup of the database tables before making changes, with the understanding that altering the data or tables is done at your own risk. ::: ## Tag History The [Historian](ignition-modules\tag-historian\tag-historian.md) system utilizes at least six different tables in the database: | Table Name | Table Description | Column References | | :--------------- | :------------------------------------------------------------------------------------------------------------------------------- | :--------------------------------- | | sqlt_data_X_X | This table stores the raw tag data. There will be multiple tables that fit this format depending on the name of the Gateway and the date. (For example, a table named "sqlt_data_1_2018_01" would store data from the driver with an id of 1, for the year 2018, for the month of January) | `sqlt_data_x_x_x.tagid = sqlth_te.id` | | sqlth_1_data | This table stores raw tag data, and is only used when the provider is configured to use a single partition (The provider's [Enable Partitioning](ignition-modules\tag-historian\tag-history-providers\tag-history-providers.md#data-partitioning) setting is unchecked). | `sqlt_1_data.tagid = sqlth_te.id` | | sqlth_te | This table stores the non-data details of each tag. | `sqlth_te.scid = sqlth_scinfo.id` | | sqlth_scinfo | This table stores tag group information. | `sqlth_scinfo.drvid = sqlth_drv.id` | | sqlth_sce | This table stores start and end times for tag groups. | `sqlth_sce.scid = sqlth_scinfo.id` | | sqlth_partitions | This table stores start and end times for each sqlt_data table. | `sqlth_partitions.drvid = sqlth_drv.id` | | sqlth_drv | This table stores information about the drivers of the historical data. | `none` | | sqlth_annotations| This table stores annotations for the historical data, such as those created by the [Power Chart](appendix\components\perspective-components\perspective-chart-palette\perspective-power-chart\perspective-power-chart.md). | `none` | ![](tag-history-tables.png) ### sqlt_data_X_X This is the central table that stores the core tag values. The system stores data in tables based on the history provider's partition length and units. For example, a monthly partition would use a table named like `sqlt_data_{driverId}_{year}_{month}`, whereas a daily partition would use `sqlt_data_{driverId}_{yearMonthDay}`. The duration of each partition is also tracked on the sqlth_partitions table. When pre-processed partitions are enabled, an additional sql_data table will be created for each partition. The system tracks which partitions are pre-processed by the "blocksize" column on the sqlth_partitions table. | Column Name | Data Type | Notes | | :------------- | :-------- | :------------------------------------------------------------------------------------------------------- | | tagid | int | Unique id of the tag. References the sqlth_te table. | | intvalue | int | Holds the value of the tag if it is data type 0, NULL otherwise. | | floatvalue | double | Holds the value of the tag if it is data type 1, NULL otherwise. | | stringvalue | string | Holds the value of the tag if it is data type 2, NULL otherwise. | | datevalue | date | Holds the value of the tag if it is data type 3, NULL otherwise. | | dataintegrity | int | Quality of the tag for this timestamp. 192 is Good Quality, anything else is bad. See [Tag Quality Overlays](platform\tags\quality-codes-and-overlays\quality-codes-and-overlays.md). | | t_stamp | long | Unix Timestamp (milliseconds since epoch) for this value. | | vtype | int | Represents metadata about the record, used for pre-processed partitions. For details, see [Pre-Processed Partitions](ignition-modules\tag-historian\tag-history-providers\tag-history-providers.md#pre-processed-partitions). | :::note Default indexing includes: - tagid - t_stamp ::: ### sqlth_1_data This is the data table for historian providers that have disabled multiple partitions (by unchecking the "Enable Partitions" setting). | Column Name | Data Type | Notes | | :------------- | :-------- | :------------------------------------------------------------------------------------------------------- | | tagid | int | Unique id of the tag. References the sqlth_te table. | | intvalue | int | Holds the value of the tag if it is data type 0, NULL otherwise. | | floatvalue | double | Holds the value of the tag if it is data type 1, NULL otherwise. | | stringvalue | string | Holds the value of the tag if it is data type 2, NULL otherwise. | | datevalue | date | Holds the value of the tag if it is data type 3, NULL otherwise. | | dataintegrity | int | Quality of the tag for this timestamp. 192 is Good Quality, anything else is bad. See [Tag Quality Overlays](platform\tags\quality-codes-and-overlays\quality-codes-and-overlays.md). | | t_stamp | long | Unix Timestamp (milliseconds since epoch) for this value. | | vtype | int | Represents metadata about the record, used for pre-processed partitions. | :::note Default indexing includes: - tagid - t_stamp ::: ### sqlth_te This table stores metadata for each historical tag. A row in this table represents a unique version of a tag's historical configuration. When a tag is modified in certain ways (renamed, data type changed, etc.), a new row is inserted and the previous entry is "retired." | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID of the tag. Primary key for this table. | | tagpath | string | Full path of the tag within the Tag Provider, e.g., `Folder1/tag1`. | | scid | int | Scan class (Tag Group) ID. References the sqlth_scinfo table, indicating the scan class this tag uses. | | datatype | int | Determines which column in the partition tables stores the tag’s historical value. **0**: Stored in **intvalue** (used for bytes, shorts, integers, longs, and booleans)**1**: Stored in **floatvalue** (used for floats and doubles)**2**: Stored in **stringvalue** (used for strings and text)**3**: Stored in **datetimevalue** (used for dates) | | querymode | int | Reflects the [Deadband Style](../../../ignition-modules/tag-historian/configuring-tag-history/configuring-tag-history.md) setting selected when tag history was enabled. **0**: Discrete, which stores values when the difference from the last stored value exceeds the deadband.**3**: Analog, which uses compression algorithms to evaluate when to store values. | | created | long | Unix timestamp (milliseconds since epoch) for when this tag entry was created. | | retired | long | Unix timestamp (milliseconds since epoch) for when this tag entry was retired. NULL means the entry is currently active. A tag is marked as retired when any of the following occur:The tag is deletedThe tag is renamedThe tag’s scan class (Tag Group) is changedThe tag’s data type is changedIf a tag is simply disabled and then deleted, this value will remain NULL. | :::note Default indexing includes: - id - scid ::: ### sqlth_scinfo This table stores information about Tag Groups, including their execution rates and associated drivers. | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | id | int | Unique id of the Tag Group. | | scname | string | Name of the Tag Group. A value of "exempt" is used when the execution rate is not recorded. | | drvid | int | The driver this Tag Group uses. References the sqlth_drv table. | :::note Default indexing includes: - id - drvid ::: ### sqlth_sce This table stores the start and end times for Tag Group execution periods. Each entry tracks execution periods for a specific Tag Group. | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | scid | int | References the sqlth_scinfo table. | | start_time | long | Unix Timestamp (milliseconds since epoch) for the first execution of this Tag Group. | | end_time | long | Unix Timestamp (milliseconds since epoch) for the latest execution of this Tag Group. | | rate | int | The execution rate (in milliseconds) of the Tag Group. | :::note Default indexing includes: - scid - start_time ::: ### sqlth_partitions This table defines the partitions used by the history system to segment data across multiple tables. Partitioning allows efficient storage and retrieval of data. | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | pname | string | The name of the table that contains this partition's data. | | drvid | int | The id of the driver that owns this data table. References the sqlth_drv table. | | start_time | long | Unix Timestamp (milliseconds since epoch) for the earliest time covered by this partition. | | end_time | long | Unix Timestamp (milliseconds since epoch) for the latest time covered by this partition. | | blocksize | int | The size (in milliseconds) of time covered by each entry, used for pre-processed partitions. | | flags | int | Additional flags affecting partition usage. For example, a flag of 1 disables seed queries. | :::note Default indexing includes: - pname - start_time ::: ### sqlth_drv This table stores information about the drivers used in the history system. Each driver corresponds to a source of historical data. | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | id | int | Unique id of the driver. | | name | string | Name of the driver. Typically, this is the system name of the Ignition Gateway storing records. | | provider | string | The name of the Tag provider associated with the driver. | :::note Default indexing includes: - id ::: ### sqlth_annotations This table stores annotations related to historical data. These are often user-created notes associated with specific data points. | Column Name | Data Type | Notes | | :------------- | :-------- | :----------------------------------------------------------------------------------------- | | id | int | Unique id of the annotation. | | tagid | int | The tag id the annotation pertains to. References the sqlth_te table. | | start_time | long | Unix Timestamp (milliseconds since epoch) for the start time of the annotation. | | end_time | long | Unix Timestamp (milliseconds since epoch) for the end time of the annotation. | | type | string | The type of annotation. Currently, the only defined type is "note." | | datavalue | string | The content of the annotation, when type is "note." | | annotationid | string | A UUID used to track the annotation across multiple Gateways. | :::note Default indexing includes: - tagid - start_time ::: ## Tag History - Internal History Provider Internal History Providers use a different table scheme compared to external providers. These tables are stored in an IDB file located at `%IgnitionInstallationDirectory%/data/var/com.inductiveautomation.historian/internalhistorian`. Note that these tables exclusively live in a SQLite database, so a database viewer is required to access them. | Table Name | Table Description | | :------------- | :--------------------------------------------------------------------------------------------------------- | | annotations | This table keeps track of annotations for specific tags. | | schema_info | Provides information on when the internal provider was created. Usually contains only one row. | | tagdata | Stores the actual historical records, along with a sync id for synchronizing data between Gateways. | | tagdetails | Provides information about tags storing data. Does not track scan class/tag group information. | | tagproperties | Tracks properties of tags, such as datatype and interpolation mode. | ### annotations | Column Name | Data Type | Notes | | :------------- | :-------- | :----------------------------------------------------------------------------------------- | | id | int | Unique id of the annotation. | | tagid | int | The tag id the annotation pertains to. Maps to the `id` column on the `tags` table. | | type | text | Type of the annotation. | | rangestart | int | Timestamp representing the start of the annotation. | | rangeend | int | Timestamp representing the end of the annotation. | | data | text | Data associated with the annotation, such as user-entered content. | | syncid | int | Sync id for synchronizing annotations with other Gateways. | | annotationid | int | A UUID used to uniquely identify the annotation. | | deleted | boolean | Indicates whether the annotation is marked as deleted. | :::note Default indexing includes: - tagid - rangestart ::: ### schema_info | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | version | int | Version of the schema. Typically set to "4." | | created | int | Unix Timestamp (milliseconds since epoch) for when the schema was created. | | flags | int | Integer flags keeping track of changes to the schema, such as upgrading from 8.1 to 8.3 or adding columns to the table. | :::note Default indexing includes: - version ::: ### tagdata | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | tagid | int | References the tag id on the tags table. | | numvalue | numeric | Numeric value of the tag, if applicable. | | strvalue | text | String value of the tag, if applicable. | | quality | int | Quality code for the value. | | t_stamp | int | Unix Timestamp (milliseconds since epoch) for the stored value. | | syncid | int | Sync id for synchronizing records across Gateways. | :::note Default indexing includes: - tagid - t_stamp ::: ### tagdetails | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | id | int | Unique id of the detail. | | tagid | int | References the tag id on the tags table. | | created | int | Unix Timestamp (milliseconds since epoch) for when this detail entry was created. | | retired | int | Unix Timestamp (milliseconds since epoch) for when this detail entry was retired. | | datatype | int | The datatype of the detail. | | syncid | int | Sync id for synchronizing records across Gateways. | | tagpath | text | The tag path of the specified tag. | | metadata | text | Any metadata properties configured on the tag, such as tooltips and documentation. | :::note Default indexing includes: - tagid - created ::: ### tagproperties | Column Name | Data Type | Notes | | :---------- | :-------- | :--------------------------------------------------------------------------------------------- | | tagid | int | References the tag id on the tags table. | | name | text | Name of the property. | | value | text | Value of the property. | | datatype | int | The datatype of the property. | :::note Default indexing includes: - tagid - name ::: ## Alarm Journal The [Alarm Journal](platform\alarming\alarm-journal\alarm-journal.md) system utilizes two different tables in the database. |Table Name|Table Description| |:---|:---| |alarm_events|This table stores every event (active, cleared, acknowledged) that happened to any alarms that fit within the Journal filter parameters. Each row is a new event|`alarm_events.id = alarm_event_data.id`| |alarm_events_data|This table stores unique information pertaining to each event. Each row is a specific property of a specific event, so alarm events with multiple properties will have multiple rows in the table.|`none`| The names of the tables are completely configurable in the Journal settings in the Gateway. The default table names are used in the table. See the [Alarm Journal](platform\alarming\alarm-journal\alarm-journal.md#database-table-definitions) page for more information regarding all of the columns in the tables. ### alarm_events This table captures the main record of each alarm event that occurred. One row is created for each change in state (active, cleared, acknowledged). | Column Name | Data Type | Notes | |--------------------|-----------|-------| | id | int | Unique ID for this event. Primary key. | | eventid | int | Identifier that groups related event records together. All active, cleared, and acknowledged states for a single alarm occurrence share the same eventid. | | source | string | The source path of the alarm, such as a tag path or expression item. | | displayPath | string | Human-readable display path of the alarm (can be overridden in alarm configuration). | | priority | int | Alarm priority level:0: Diagnostic1: Low2: Medium3: High4: Critical | | eventtype | int | Alarm state change:0: Active1: Cleared2: Acknowledged4: An alarm was enabled5: An alarm was disabled | | eventflags | int | Bitmask representing metadata about the event. Each bitmask and their corresponding metadata is listed below. Bit 0: System Event - One of the designated system events, such as system startup and system shutdown.Bit 1: Shelved Event - The alarm was shelved at the time that the event occurred. Shelving alarms does not prevent execution, so if the Journal is configured to store shelved events, they will be stored even if they're not sent to the notification system, or shown to users.Bit 2: System Acknowledgement - When the Live Event Limit property's threshold in the Gateway's general alarm settings is exceeded, the system will automatically acknowledge overflow events, and the acknowledgement event will have this flag set.Bit 3: Acknowledged Event: The event was acknowledged at the time of the event. Used for events that are cleared after being acknowledged.Bit 4: Cleared Event - The event was cleared at the time of the event. Used for alarms that are acknowledged after being cleared.Bit 5: Enabled - Signifies that the enabled state on the alarm was changed. | | eventtime | datetime | Timestamp for when the event occurred. | :::note Default indexing includes: - id ::: ### alarm_events_data This table stores event-specific properties, such as custom alarm properties or tag values at the time of the event. Each row represents one property for one event. | Column Name | Data Type | Notes | |--------------------|-----------|-------| | id | int | References the id from the alarm_events table. | | propname | string | Name of the property (e.g., "AckUser", "Notes", or "IsShelved"). | | dtype | int | Represents the type of value stored in this row:0 = Integer1 = Float2 = String | | intvalue | int | Value of the property if dtype = 0. Otherwise NULL. | | floatvalue | float | Value of the property if dtype = 1. Otherwise NULL. | | strvalue | string | Value of the property if dtype = 2. Otherwise NULL. | :::note Default indexing includes: - id ::: ## Authentication The [Database Authentication](platform\security\classic-authentication-strategy\database-authentication\database-authentication.md) system utilizes six different tables in the database: |Table Name|Table Description|Column References| |:---|:---|:---| |scada_users|This table stores each user contained within the user source, along with basic user information. Each row is a new user.|`none`| |scada_roles|This table stores all of the possible roles within the user source. Each row is a new role.|`none`| |scada_user_rl|This table stores a mapping of users to roles. Each row is a user and a paired role, so users with multiple roles will have multiple rows in the table.|`scada_users_rl.user_id = scada_users.id
scada_users_rl.role_id = scada_roles.id`| |scada_user_sa|This table stores a list of all upcoming schedule adjustments for each user. Each row is a new schedule adjustment, so users with multiple schedule adjustments will have multiple rows in the table.|`scada_user_sa.user_id = scada_users.id`| |scada_user_ci|This table stores a list of all contact information items for each user. Each row is a new contact information item, so users with multiple contact information items will have multiple rows in the table.|`scada_user_ci.user_id = scada_users.id`| |scada_user_ex|This table stores a list of all extra properties for each user, with properties and values stored 1 for 1. Each row is a new property and value pair, so users with multiple extra properties will have multiple rows in the table. Extra properties are added for modules that want to associate data with a user, such as the Voice Notification Module, which adds a Security PIN setting.|`scada_user_ex.user_id = scada_users.id`| The prefix of the tables are configurable in the User Source settings in the Gateway. The default prefix of "scada_" is used in the table. ### scada_users This is the core user table. It contains authentication credentials and general profile information for each user. | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID for the user. | | username | string | The user's login name. | | password | string | Encrypted password hash. | | firstname | string | User’s first name. | | lastname | string | User’s last name. | | schedule | string | Assigned schedule name (for On-Call Roster or Scheduled Roster logic). | | notes | string | Optional user notes. | :::note Default indexing includes: - id ::: ### scada_roles Stores all defined roles that can be assigned to users. | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID for the role. | | name | string | Name of the role (e.g., "Administrator", "Operator"). | :::note Default indexing includes: - id ::: ### scada_user_rl Links users to their assigned roles. One row per user-role pair. | Column Name | Data Type | Notes | |-------------|-----------|-------| | user_id | int | References scada_users.id. | | role_id | int | References scada_roles.id. | :::note Default indexing includes: - user_id - role_id ::: ### scada_user_sa Stores schedule overrides or adjustments for individual users. | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID for the schedule adjustment. | | user_id | int | References scada_users.id. | | starttime | datetime | When the schedule adjustment starts. | | endtime | datetime | When the schedule adjustment ends. | | type | string | Type of adjustment (e.g., "Available", "Unavailable"). | :::note Default indexing includes: - user_id ::: ### scada_user_ci Stores pieces of contact info for users, such as emails or phone numbers. | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID for the contact info entry. | | user_id | int | References scada_users.id. | | type | string | Type of contact (e.g., "Email", "Phone"). | | value | string | Contact information value. | :::note Default indexing includes: - user_id ::: ### scada_user_ex Stores custom or extra properties for a user. Often used by modules (e.g., Voice Notification) to store settings like PIN codes. | Column Name | Data Type | Notes | |-------------|-----------|-------| | id | int | Unique ID for the property. | | user_id | int | References scada_users.id. | | name | string | Name of the property (e.g., "VoicePIN"). | | value | string | Value of the property. | :::note Default indexing includes: - user_id ::: ## Audit Log The [Audit](platform\audit-log-and-profiles\audit-log-and-profiles.md) system stores its data in the following database table. On Oracle databases, the audit log uses a sequence named `audit_events_seq`, which must be accounted for if `audit_events` is manually dropped or renamed. |Table Name|Table Description|Column Reference| |:---|:---|:---| |audit_events|This table stores each auditable event (save, edits, etc.) that has happened for each project or system that has auditing enabled. Each row is a new event.|`none`| The names of the tables are completely configurable in the Audit settings in the Gateway. The default table names are used in the table. :::note Be aware of case sensitivity when referencing audit table and column names, as these names are lowercase. ::: ### audit_events | Column Name | Data Type | Notes | |---------------------|-----------|-------| | audit_events_id | int | Unique identifier for the event. Primary key. | | event_timestamp | datetime | Timestamp for when the action occurred. | | actor | string | The user or system that performed the action. | | actor_host | string | Hostname or IP of the system where the action originated. | | action | string | Brief description of the action (e.g., "Tag Write", "Script Run"). | | action_target | string | The target affected by the action (e.g., tag path, script name, user). | | action_value | string | The value involved in the action (e.g., written value, changed property). | | status_code | int | A 32-bit integer bitmask representing the result of the action (e.g., good, bad, uncertain).Refer to [AuditStatus.SubCode](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/util/AuditStatus.SubCode.html) for decoding specific status codes. | | originating_system | string | Name of the project or system that performed the action. | | originating_context | int | Numeric bitmask representing the context of origin:1 = Gateway2 = Designer4 = Client | :::note Default indexing includes: - audit_events_id - event_timestamp :::
