title: "Gateway XML File Reference"
description: "This page describes the gateway.xml file located in the installation directory"
# Gateway XML File Reference
:::note
This page talks about the `gateway.xml` file. If you are instead looking for information on the Gateway Configuration file, also called `ignition.conf`, click [here](appendix\reference-pages\gateway-configuration-file-reference\gateway-configuration-file-reference.md).
This section details the various configuration changes that can be made to the `gateway.xml` file. Select networking properties, such as port configuration, Gateway SSL properties, and more will be covered here. Many of these settings can also be modified in the Gateway's [Web Server settings](platform/gateway/web-interface/network/web-server-settings/web-server-settings.md).
### Property Format
The properties in the gateway.xml file follow the convention below:
|Format|Example|
|`Context Settings`|`8088`|
## Configuration File Location
The `gateway.xml` file can be found at:
`%IgnitionInstallationDirectory%/data/gateway.xml`
See the [Installing and Upgrading Ignition](getting-started\installing-and-upgrading\installing-and-upgrading.md#ignition-default-installation-directories) page for default installation directories.
## Gateway XML Properties
The table below lists all the properties found in the `gateway.xml` file.
:::caution
Keep in mind that while these properties can be modified, most installations won't need to. If you are interested in changing these properties, please read through the descriptions thoroughly, and consult with our support department before proceeding.
|System Property|Description|
|``|The public facing HTTP port that Vision Clients and Perspective Sessions must use to connect, such as `80`. No default value.|
|``|Set this property to `false` to specify an explicit HTTP address that Vision Clients and Perspective Sessions will use. Most users will leave autodetect on. Default is `true`.|
|``|The public facing HTTPS port that Vision Clients and Perspective Sessions must use to connect. If Force Secure Redirect is enabled, redirected connections will use this port. No default value.|
|``|If both this property and SSL/TLS are enabled, all HTTP traffic will be redirected to its HTTPS counterpart. Default is `false`.|
|``|The port to which Ignition will listen for incoming HTTPS traffic over the Gateway Area Network (GAN). Default is `8060`.|
|``|Whitelist of included cipher suits for clients connecting to Ignition using SSL/TLS. Default is an `empty array []`.|
|``| When automatic backups are enabled, this setting determines the delay between backups of Ignition's config.idb file, in `minutes`. The backup file is generated in the `%IgnitionInstallationDirectory%/data/db/autobackup` folder. Default is 60.|
|``|Whether or not the Gateway will use autobackups of Ignition's config.idb file. If false, this property does not prevent the Gateway from creating autobackups, as this is managed by `localdb.autobackup.count`. Default is `true`.|
|``|The port to which Ignition will listen for incoming webserver HTTPS traffic, such as Designers, Vision Clients, Perspective sessions, and Gateway web configuration settings. Default is `8043`.|
|``|Identifies which version of the context properties the `gateway.xml` file uses. Default is `3`.|
|``|The port to which Ignition will listen for incoming HTTP traffic. Default is `8088`.|
|``|When enabled, the Gateway inspects each incoming HTTP request in search for headers that indicate it has been forwarded by one or more proxies. If these headers are present, then the request is updated so that the proxy is not seen as the other end point of the connection from which the request originated. Default is false. Warning: Enabling this setting when users can directly connect to the Gateway is a security risk. This setting is intended to be used in scenarios where untrusted users will not be able to bypass a trusted proxy that is responsible for setting the appropriate headers. For more information, see [Use Proxy Forwarded Headers Explained](platform/gateway/web-interface/network/web-server-settings/web-server-settings.md#use-proxy-forwarded-headers-explained).|
|``|The number of automatic Gateway backups for Ignition's config.idb file that will be retained before old backups are overwritten. When this property is set at 0, automatic config.idb backups are prevented. Any value greater than zero will enable automatic backups, and then that value will be used for the retention amount. The default value changed from 5 to 0, meaning that automatic backups are disabled by default in 8.3.8+.|
|``|The maximum number of webserver threads that are allowed. Webserver threads are needed when communicating with the Gateway or if a subsystem does not have its own thread pool. Some example subsystems that use webserver threads are:The Gateway webpageThe DesignerVision ClientsWebDev module requestsDefault is `300`. The Gateway now logs warnings once per minute if more than 90 percent of Gateway webserver threads have been consumed. This logger is an indication that your webserver max threads setting may need to be increased to maintain expected functionality. Starting in version 8.3.2, the `gateway.maxThreads` setting no longer applies to the Gateway Network as the Gateway Network will now use its own [thread pool](platform/gateway-network/gateway-network.md#main) to process incoming messages. This update eliminates issues with the Gateway becoming unresponsive when handling a large volume of Gateway Network requests. |
|``|The number of backups from Ignition's faulted `config.idb` file. Backups of faulted `config.idb` files will follow a naming convention containing `faulted_` as a prefix. Default is `3`.|
|``|The relative directory in which the data directory is stored at. Used when the web server parses information for web resources and settings outside of a Gateway context. This allows for the data directory to be used for both Gateways and commissioning. Modifying this property will require that files from the previous data folder are migrated to the new destination. Default is `data\`.|
|``|When enabled, Ignition's web server will attempt to resolve the remote HTTP client's hostname by performing a reverse DNS lookup using the remote HTTP client's IP address where appropriate. Enabling this setting could have a performance impact as the Gateway may attempt an expensive hostname lookup when handling requests. When disabled, Ignition's web server will not attempt to resolve hostnames, and any queries for the remote HTTP client's hostname will result in their IP address instead.When enabling this setting, it is highly recommended that reverse DNS is configured to prevent host lookup failures. This includes configuring valid mappings from users' IP addresses to their hostnames, and from users' hostnames back to their IP addresses. If reverse DNS isn't configured, then DNS queries could block certain requests until the queries time out (default of 10 seconds).Default is `false`.|
|``|Controls how many connections are allowed against the Gateway port, also known as the accept queue size or accept backlog. Default is `100`.|
|``|Blacklist of excluded cipher suits for clients connecting to Ignition using SSL/TLS. Takes precedence over allowed cipher suits. Default is an `empty array []`.|
|``|The public facing address that Vision Clients and Perspective Sessions must use to connect, such as `yourcompany.com`. If Force Secure Redirect is enabled, redirected connections will use this address. No default value.
