Vision - Comments Panel Scripting Functions
This page details the various component and extension functions available for Vision's Comments Panel component.
Component Functionsβ
This component does not have component functions associated with it.
Extension Functionsβ
insertNoteβ
- Description
- Called when a note is added.
- Parameters
- component self - A reference to the component that is invoking this function
- string note - The text contents of the note
- string filename - The full filepath to the the attachment
- string sticky - A boolean indicating whether this note should be flagged as stickied
- Return
- None
deleteNoteβ
- Description
- Called when a user clicks the 'delete' link on a note.
- Parameters
- integer id - The id of the note
- Return
- None
unstickNoteβ
- Description
- Called when a user clicks the 'unstick' link on a note.
- Parameters
- Return
- None
downloadAttachmentβ
- Description
- Called when a user attempts to download an attachment from a note.
- Parameters
- Return
- None
canDeleteβ
- Description
- Returns whether or not a note with the given id can be deleted. Notes that return True will show a 'delete' link.
- Parameters
- Return
- boolean - Notes with a True return can be deleted by the user, False return can not be deleted.
