--- title: "Vision - PDF Viewer Scripting Functions" --- # Vision - PDF Viewer Scripting Functions > This page details the various component and extension functions available for Vision's PDF Viewer component. > Component Functions This page details the various component and extension functions available for Vision's PDF Viewer component. ## Component Functions ### .loadPDFBytes(bytes, name) * Description * This function will pass in the bytes of a PDF and load them into the PDF Viewer component. Please see [Storing Files in a Database](platform/sql-in-ignition/common-sql-tasks/storing-files-in-a-database/storing-files-in-a-database.md) for more details * Parameters * string **bytes** - The bytes of the PDF to be displayed on the component * string **name** - The name of the PDF * Return * None ### .print(showDialog) * Description * This function will print the PDF. * Parameters * boolean **showDialog** - If true, shows the user a print dialog. Default is true [optional] * Return * None ### .setZoomFactor(zoom) * Description * This function will set the current zoom level of the PDF, adjusted to stay within the minimum / maximum zoom range. Will zoom in on center of page. * Parameters * float **zoom** - Zoom factor to use. 1.0 is no zoom. * Return * None ## Extension Functions This component does not have extension functions associated with it.
