Version: 8.3
Vision - Pipe Segment
Component Palette Icon:
The pipe segment component displays a quasi-3D pipe. In its basic form it looks very much like a rectangle with a round gradient. The difference comes in its advanced rendering of its edges and endcaps. You can configure each pipe segment's end to mate perfectly with another pipe segment butted up against it perpendicularly. The result looks like a pipe welded together in a 90Β° corner.
The control of the pipe's ends are done using 6 booleans - three per 'end'. End 1 is the top/left end, and End 2 is the bottom/right end. You turn off each boolean if there will be another pipe butted up against that side. The following diagram illustrates the naming conventions:
Properties​
NameDescriptionProperty TypeScriptingCategory
BorderThe border surrounding this component. Options are No border, Etched (Lowered), Etched (Raised), Bevel (Lowered), Bevel (Raised), Bevel (Double), and Field Border.
Note: The border is unaffected by rotation.
Border.borderCommon
Center FillThe center of the fill gradient. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.Color.mainColorAppearance
CursorThe mouse cursor to use when hovering over this component. Options are: Default, Crosshair, Text, Wait, Hand, Move, SW Resize, or SE Resize.int.cursorCodeCommon
Edge FillThe edge of the fill gradient. See Color Selector.Color.secondaryColorAppearance
End 1 Bottom?Draw the border at end #1's bottom?boolean.end1BottomAppearance
End 1 Cap?Draw the border at end #1's cap?boolean.end1CapAppearance
End 1 Top?Draw the border at end #1's top?boolean.end1TopAppearance
End 2 Bottom?Draw the border at end #2's bottom?boolean.end2BottomAppearance
End 2 Cap?Draw the border at end #2's cap?boolean.end2CapAppearance
End 2 Top?Draw the border at end #2's top?boolean.end2TopAppearance
Mouseover TextThe text that is displayed in the tooltip which pops up on mouseover of this component.String.toolTipTextCommon
NameThe name of this component.String.nameCommon
Outline ColorThe color of the outline border. See Color Selector.Color.outlineColorAppearance
QualityThe data quality code for any Tag bindings on this component.QualityCode.qualityData
StylesContains the component's styles.Dataset.stylesAppearance
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Scripting​
Component Functions​
This component does not have component functions associated with it.
Extension Functions​
Event Handlers​
Customizers​
