Vision - Pipe Joint
Component Palette Icon:
Descriptionβ
The pipe joint displays a joint component to join two pipe segments together. By turning off the cardinal directions, this will display a two-, three-, or four-pipe union.
Propertiesβ
| Name | Description | Property Type | Scripting | Category |
| Border | The border surrounding this component. Options are No border, Etched (Lowered), Etched (Raised), Bevel (Lowered), Bevel (Raised), Bevel (Double), and Field Border. Note: The border is unaffected by rotation. | Border | .border | Common |
| Bottom? | Indicates if the joint has an outlet at the bottom. | boolean | .bottom | Appearance |
| Center Fill | The center of the fill gradient. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. | Color | .mainColor | Appearance |
| Cursor | The mouse cursor to use when hovering over this component. Options are: Default, Crosshair, Text, Wait, Hand, Move, SW Resize, or SE Resize. | int | .cursorCode | Common |
| Edge Fill | The edge of the fill gradient. See Color Selector. | Color | .secondaryColor | Appearance |
| Left? | Indicates if the joint has an outlet at the left. | boolean | .left | Appearance |
| Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common |
| Name | The name of this component. See Color Selector. | String | .name | Common |
| Outline Color | The color of the outline border. See Color Selector. | Color | .outlineColor | Appearance |
| Quality | The data quality code for any Tag bindings on this component. | QualityCode | .quality | Data |
| Right? | Indicates if the joint has an outlet at the right. | boolean | .right | Appearance |
| Styles | Contains the component's styles | Dataset | .styles | Appearance |
| Top? | Indicated if that joint has an outlet at the top. | boolean | .top | Appearance |
| Visible | If disabled, the component will be hidden. | boolean | .visible | Common |
Scriptingβ
Component Functionsβ
This component does not have component functions associated with it.
Extension Functionsβ
Event Handlersβ
