--- title: "Report - Pencil Shape" description: "The Pencil shape component lets you draw free-hand path segments that automatically smooth the curves." --- # Report - Pencil Shape > The Pencil shape component lets you draw free-hand path segments that automatically smooth the curves. The Pencil shape component lets you draw free-hand path segments that automatically smooth the curves. Using a Pencil shape can emphasize an area or an item on a report. Select the Pencil shape on the Report Design Palette to make it active, and draw a free-hand path anywhere in the Report Designer. If you stop drawing inside the small square that is placed at the shape's origin, then you will create a closed path, otherwise, you'll create an open path (line). Once a path is created, you can use the handles to change its width and height. You can also change its stroke style, color, and more. ![](pencilShape.png) **Report Design Component Palette Icon** ![](pencilIcon.png) ## Properties ![](pencilProps.png) |Property|Description| |---|---| |Fill|If true, the shape will fill its space with color.| |Fill Color|If Fill is selected, the color that will fill the shape.| |Opacity|How opaque the fill color is, between 0 and 1.| |Stroke Style|What style of stroke or border to use: Hidden; Shape Outline; Border; Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md).| |Stroke|[Details for the chosen stroke](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md). Each Stroke has its own properties depending on the Stroke Style chosen.Color - Color to use for the stroke or border.Dash Pattern - A "Dashed Pattern" string to specify the nunber of pixels on and off. For example, "5,10"Width - Width of the stroke in pixels.| |Roll|Number of degrees this shape is rotated clockwise.| |Scale X|Amount to scale the width of this shape. 1 is scale to 100%.| |Scale Y|Amount to scale the height of this shape. 1 is scale to 100%.| |URL| A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.Page:Next - Navigates to the next page.Page:Back - Navigates to the previous page.Page:Number - Replace "Number" with a numeral. Navigates to the specified page.| |Visible|If true, the shape will be visible.| |Width|Width of this shape in pixels.| |Height|Height of this shape in pixels.| |X|Horizontal distance in pixels between the left edge of this shape and the left edge of the page.| |Y|Vertical distance in pixels between the upper edge of this shape and the top edge of the page.| ## Example This example shows possible values to set Pencil stroke properties. ![" "](example.png) |Property|Value| |---|---| |Stroke Style|Shape Outline| |Stroke Color|FF0000| |Stroke Width|6 pixels|
