Version: 8.3
Report - Ellipse Shape
The Ellipse shape component creates circles and ellipses that can be used in a report. Select the Rectangle shape on the Report Component Palette to make it active, and click and drag to draw an ellipse anywhere in the Report Designer. Once an ellipse or circle is created, you can use the handles to change its width and height. Hold Shift to force the shape into a circle. You can also change its stroke style, color, start angle, and sweep angle.
Report Design Component Palette Icon:
Properties​
PropertyDescription
FillIf true, the shape will fill its space with color.
Fill ColorIf Fill is selected, the color that will fill the shape.
OpacityHow opaque the fill color is, between 0 and 1.
Stroke StyleWhat style of stroke or border to use: Hidden; Shape Outline; Border; Double. To learn more about stroke styles, refer to Stroke and Fill Properties.
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.
  • Color - Color to use for the stroke or border.
  • Dash Pattern - A "Dashed Pattern" string to specify the nunber of pixels on and off. For example, "5,10"
  • Width - Width of the stroke in pixels.
RollNumber of degrees this shape is rotated clockwise.
Scale XAmount to scale the width of this shape. 1 is scale to 100%.
Scale YAmount to scale the height of this shape. 1 is scale to 100%.
URLA link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.
  • Page:Next - Navigates to the next page.
  • Page:Back - Navigates to the previous page.
  • Page:Number - Replace "Number" with a numeral. Navigates to the specified page.
VisibleIf true, the shape will be visible.
WidthWidth of this shape in pixels.
HeightHeight of this shape in pixels.
XHorizontal distance in pixels between the left edge of this shape and the left edge of the page.
YVertical distance in pixels between the upper edge of this shape and the top edge of the page.
Start AngleWhere to start the sweep angle, in degrees. 0 is at 3 o'clock.
Sweep AngleHow many degrees the oval is swept. 0 shows just a line, 360 shows the full oval.
Example​
PropertyValue
Stroke StyleShape Outline
Stroke - ColorFF0000
Stroke - Width5 pixels
Sweep Angle360
